Shifting into 4H.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Canlab, Jan 10, 2024.
  1. Jan 10, 2024 at 3:28 PM
    Canlab
    Canlab [OP] New Member
    I have a brand new 2023 Tacoma. Today while driving on the highway I attempted to switch to 4wd but light started blinking. I let off the throttle and then it went solid green. I was traveling below 62, but was slightly accelerating. I tried it again later and same thing, had to let off the throttle and coast to go in. Is this normal? Is it normal procedure to have to let off the throttle before engaging 4H?
  2. Jan 10, 2024 at 3:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup coast, no load, straight line.
    texbaz, Chew, CVCV and 5 others like this.
  3. Jan 10, 2024 at 3:29 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    It flashes when it is engaging, and is solid when it is fully engaged. This is normal.
    You do not have to take your foot off the gas, but I wouldn't flog it......
    For best results, read your manual.
  4. Jan 10, 2024 at 3:45 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Practice makes perfect.
    Tocamo likes this.
  5. Jan 10, 2024 at 3:47 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Normal. In the 3 years I had my Tacoma I never had a 4wd engagement with load. Always had to coast.
    devinzz1 and soundman98 like this.
  6. Jan 10, 2024 at 3:51 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Yep agree. Read the manual ask questions if you don’t understand. If not you will be back in here in a few months asking why you hear a loud grinding and why it won’t go into 4 hi or lo.
    Chew, tuktoyaktuktoyota and wilcam47 like this.
  7. Jan 10, 2024 at 4:26 PM
    gudujarlson
    Minnesota
    Don’t over think it. The 2hi <=> 4hi transition is very reliable when moving in a straight line at a constant hiway speed. It’s a very frequent thing during winter in places where it snows.
    Jeffch likes this.
  8. Jan 10, 2024 at 4:43 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    completely normal and not just unique to toyota.
    Chew likes this.
  9. Jan 10, 2024 at 4:46 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Don’t disengage 4hi when the driveline is under load. You’ll get a big bang from the transfer case driveline. Always engage and disengage when coasting
    Chew, CVCV and joba27n like this.
  10. Jan 10, 2024 at 8:13 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I prefer engaging at a standstill. Thoughts are fewer moving parts fewer possibilities for something to go very wrong.
    Squirt and PTSDTherapy like this.
  11. Jan 10, 2024 at 8:15 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Behavior is normal.
    ^- This is it exactly.
  12. Jan 10, 2024 at 8:20 PM
    TedTRD
    TedTRD Well-Known Member
    Charles
    2023 Tacoma TRD
    I prefer to take it easy and coast as shifting into 4-high. Very simple and much better than the old days when you had to get out, backup and lock the hubs.
    JG1980 likes this.
  13. Jan 10, 2024 at 8:21 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I thought the manual said to do while moving.
  14. Jan 10, 2024 at 8:31 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    All good advise. Just don’t forget to engage 4hi at least once a month. Even in the city on asphalt. Just make sure you are driving straight. Do it a number of times. Keeps everything working.
    Irons and Gfenza89 like this.
  15. Jan 10, 2024 at 8:40 PM
    gudujarlson
    Minnesota
    That’s unreliable and impractical in my experience.
  16. Jan 10, 2024 at 8:52 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    4H to 4L or vice versa, yes….2H to 4H and vice versa, no, not at all.
    khax likes this.
  17. Jan 10, 2024 at 8:54 PM
    BLtheP
    Plano, TX
    The system shifts the transfer case pretty much immediately. The remainder of the shift is typically the ADD moving the fork over on the front diff. Turning the steering wheel slightly can help with this because the fork has to match the right side axle shaft splines up to the intermediate shaft which is going the same speed as the left wheel and rear wheels. Turning just slightly takes away the misalignment and lets the fork slide over to do its thing. Otherwise you may experience 3-5 seconds of blink before the ADD completes the shift.
    Kbar, khax and Canadian Caber like this.
  18. Jan 11, 2024 at 2:19 AM
    PTSDTherapy
    22 SR5 DCSB
    This is true but I’d do anything to have those hubs back on my Tacoma.
    Kodiak420 likes this.
  19. Jan 11, 2024 at 2:43 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    You planning to do a solid axle swap then? I mean, you did say you'd do "anything" to get them. :evil:
    Squirt likes this.
  20. Jan 11, 2024 at 3:24 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    If you have a locker, I'd also advise to exercise engaging that periodically too.... for the same reason. Just do it under proper conditions for locking.
    .... Like me trying to scare Mrs. Arc going up our 400+ foot driveway locked and backwards in the snow as fast as can.... just cuz I can :rofl:
