Shifting into 4L: Whats your experience w/ 3rd Gen manuals
Discussion in '3rd Gen. Tacomas (2016-2023)' started by guitarcarl, May 13, 2016.
  1. May 13, 2016 at 9:38 AM
    guitarcarl
    guitarcarl [OP] Active Member
    Seattle, WA.
    A slow 2016 MGM Taco SR 4x4 2.7L 5 spd Manual
    OR Wheels, ATC LTD Cap, Intermittent Wiper Mod.
    I have the 2.7L with 5 spd man. w/ apx 600 miles on the new truck and haven't taken it off road yet. I am planning a trip to Utah and will be using the 4x4 4L at that time.
    I have read the owners manual and I have tested that the truck shifts into 4H (no need to use the clutch) and 4L (the manual indicates using the clutch to go into 4L) when going up a sharp gravel driveway to prevent wheel spin.
    The truck seems to shift into 4H easily, but as I stop. put the clutch in and try to go into 4L I get the beep-beep and blinking light and don't hear the mechanism engaging. I often have to roll/drive a short distance and try again often several times before it definitively goes into 4L. The manual indicates if you get the beep/blink to try again.
    Is this a normal experience? How do others experience shifting to 4L?
  2. May 13, 2016 at 9:59 AM
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    After I turn the switch to 4L, I give it a just a little roll and it usually engages. Make sure you are at a rest when turning the switch.
  3. May 13, 2016 at 10:21 AM
    guitarcarl
    Seattle, WA.
    Do you roll with or without the clutch engaged? I guess gears have to mesh correctly?
  4. May 13, 2016 at 10:25 AM
    COskimtb
    Without. Exactly.
