shifting into 4wd help
Discussion in '1st Gen. Tacomas (1995-2004)' started by exwrx, Dec 6, 2012.
  1. Dec 6, 2012 at 6:34 PM
    exwrx
    exwrx [OP] Well-Known Member
    Walkerton, ont
    05 Silver DC Taco TRD
    stock
    hi, asking for my dad. he has a 2002 tacoma ext cab trd automatic v6 4x4. we were out for a drive tonight and were trying to figure out the shift pattern. i believe the 4wd shifter has 4wd lo at the top, then neutral, the 4wd high at the bottom(closer to the back seat). there is a 4wd button on the shifter that acivates 4x4 (i think)... the gear shifter (p,r,n,d.3,2,1) has a over drive button on the side of it.
    so was he doing it right? also what are safe speeds to enter 4x4 high and 4x4 low. thinking 60km/h for 4x4 high and 0 km/h for low in neutral.
    thanks for the help!!
  2. Dec 7, 2012 at 1:25 AM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    Entering and exiting 4WD should be done at a stop I believe. At least that's how the rear lockers are recommended to be activated.
  3. Dec 7, 2012 at 1:35 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    lmao how old are you and you guys dont have a manual inside the glove compartment or a fancy sticker somewhere on there? its an automatic so I wouldnt go over 15mph when I hit the button to engage 4high. i'd shift it down into 4 low at a stop though.
  4. Dec 7, 2012 at 1:57 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I shift into four high up to 50mph, but I think the manual says up to 55. For 4low I stop the truck and put the transmission into neutral before I put it in 4low.
  5. Dec 7, 2012 at 4:49 PM
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Now if only there was snow to have some four wheel fun
  6. Dec 7, 2012 at 5:58 PM
    exwrx
    Walkerton, ont
    stock
    thanks for the info. seems simply enough just wanna make sure he does not do any damage to his truck.
  7. Dec 11, 2012 at 3:43 PM
    Mr. Biscuits
    Brennen J
    Bakersfield
    why shift on the go? doesnt seem like any advantage to shifting while moving instead you might screw something up. hell you used to have to get out to activate the damn things (some prefer it) so i would just stop. activate. go.
  8. Dec 11, 2012 at 3:49 PM
    ffirg
    mike
    Anchorage, Alaska
    I shift on the go because I have to. The roads up here are constantly icy and sometimes I need 4wd if I'm going up an incline. I can't just stop in the middle of traffic and shift when it's perfectly normal to shift on the go...The user manual of our trucks even says you can do it up to 55 mph. The only reason you would mess anything up is if you were turning sharp and have the pedal to the floor while shifting into 4wd. If you let off the gas and keep the wheel straight you shouldn't have any issues.
  9. Dec 17, 2012 at 3:01 PM
    bishard
    bishard Member
    97 4runner 5spd 3rz
    Love on the fly transfer. Just go charge the obstacle full boar without stopping. My 2.7 5 spd 4runner says shift in or out as long as below either 50 or 55 I cant remember.
  10. Dec 17, 2012 at 4:25 PM
    Kala
    BigIsland
    05 PreRunner SR5
    If it really matters...these transfer cases can handle being shifted into 4wd at over 50mph with a supercharger. Worked when I was drunk. Even did 4wd burn outs. i wouldnt worry about it...plus easy to find if it breaks. ;)
  11. Dec 18, 2012 at 6:58 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod, Kobalt tool box, Bulldog Keyless entry, Sportsman max-4 seat covers, modded EL Bazooka basstube, Friends of Coal sticker and license plate, Green Hooks, Green Emblems, Green LED sony radio, Green shiftknob.
    my manual says 35 for 4hi and thats in the case of emergency, ive done it while creeping maybe 10mph max? it falls right in, sometimes it goes in easier. my truck is a manual with twin stick transfer case. 4lo always stop cause it is geared so low. no need to use it really just if your wantin to creep around with good torque
    Edit: normally you should put it into 4wd before you think your going to need it. these trucks are so light in the back, if your doubtin needing it. you will prolly need it. better safe than sorry.
  12. Dec 18, 2012 at 7:02 AM
    ALawrence
    ALawrence Well-Known Member
    Andrew
    Oklahoma City
    03 Tacoma Sr5 Double cab 4x4
    pics or it didnt happen. haha
  13. Dec 18, 2012 at 8:19 AM
    Kala
    BigIsland
    05 PreRunner SR5
    Dont worry...didnt happen.;)
    With the negative reps from clowns on here being cry babies...I think i'll refrain from posting stupid stuff. If you look around I think theres vids still out there. All the pics I had crashed on my old computer. I had fun with the truck...maybe i'll dig out some shit later. :)
  14. Dec 18, 2012 at 11:19 AM
    ALawrence
    Andrew
    Oklahoma City
    just giving you hell man.
