shifting into drive - lurches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, Jun 30, 2020.
  1. Jun 30, 2020 at 3:15 PM
    mrcheap
    mrcheap [OP] Well-Known Member
    just a quick question
    when i shift my 05 trd sport dclb into drive it seems to lurch a bit
    i plan on doing a drain and fill of the tranny fluid - but just wanted to know if this is a sign of anything.
    it does have 155k on on it (and its new to me of course)
    thx
  2. Jun 30, 2020 at 3:17 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Check U joints first. You'd likely hear a clunk but not all of the time. Just shake the shaft and see if there's play. I would shove some grease in there and see if that remedies the issue.
  3. Jun 30, 2020 at 3:40 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't think you have a problem. Compared to other vehicles I've owned my Tacoma has very little lag time between shifting from park or neutral into either Drive or Reverse. As soon as the lever is in D, or Rit is ready to go. With others there is a slight delay between shifting and the vehicle being ready to move. I think you just need to get used to the way your new truck behaves.
  4. Jun 30, 2020 at 4:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the lurching just after you first start the truck and shift in to D?
    If so, does it “lurch” more than once in quick succession?
    Or
    Does it “lurch” anytime it’s in gear with A/C on.
    Example: At a stop sign or light, and the A/C is on.
    Typically people describe it as some one has tapped you in the rear of the truck.
    trucknrv likes this.
  5. Jul 1, 2020 at 7:40 AM
    trucknrv
    trucknrv Active Member
    Western MA
    22 TRD sport
    Snowsport plow with front receiver hitch, Access lorado tonneau cover, AVC ventshades, Covercraft seat covers, Husky floor mats, K-N filter, Hydraulic lift arms for hood, Factory black running boards, Direct cable from battery for jumper cables, Oil plug valve, Front anytime camera, Baja design fog lights, Bed mat, Borla exhaust with black tip, TRD skid plate along with stainless cat plate, 6 new speakers, Puddle lights, Floorwell lighting, Aftermarket heated seats, Interior LED lights, Swing tool box for the bed, Redarc brake controller, Blackout kit, Ceramic coated, Timbren load boosters, LED bed lights, Zprecision bigger cup holder, Drivers grab handle, License plates negated when in reverse, Sequential smoke mirror lights, Bumper step, 3rd brake light smoked out, Factory painted door edge guards, Door sill protectors, Mesa stick shift with additional buttons for the ECT, Extra 110V plug for the back seat and anytime 400 W plug for the bed, OTT tune, Protech for radio and dash film, Bigger radio knobs, LED hood light, Added LED strip backup light under the tailgate, AlphaRex tail lights. I am sure there is more but wife is starting to give me the side eye to add more! Like I heard they are not mods but it's a BUILD!
    What you described in the lurch part with the A/C on is what is happening to my truck. I checked the A/C yesterday at a place that services A/C's and they said it seems plenty cold and doesn't need a recharge. I am experiencing this slight push at a stop with the A/C on. I have a 2008 Tacoma Sport 4x4 double cab with 136 K on it. You have a solution TnShooter??
  6. Jul 1, 2020 at 9:13 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    My 2006 also does this from day 1. I’d say normal
    TnShooter likes this.
  7. Jul 1, 2020 at 10:42 AM
    TnShooter
    Deogee
    STOCK
    Yes, this is considered Normal.
    There’s been many others report of it. Even mine does it.
  8. Jul 1, 2020 at 11:00 AM
    mrcheap
    ok thanks - sorry for the late reply been busy with work
    im glad its no major concern but ill still do the preventive maintenance like fluid changes and grease the appropriate areas!
  9. Jul 1, 2020 at 11:02 AM
    regtaco
    regtaco Well-Known Member
    Lee
    Knoxville/Franklin TN
    07 Reg cab 4x4
    Toytec 3 inch lift kit with: OME 884 coils, OME Nitro shocks, custom driveshaft, diff drop
    Definitely normal. My dad’s 4Runner does it too
