Shifting into gear issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Jun 28, 2017.
  1. Jun 28, 2017 at 8:54 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I drive an automatic V-6... whenever shifting from park to reverse for park to drive it's a hard shift… Feels like my transmission is going to fall off… Any suggestions on what to troubleshoot first? The truck has about 230,000 miles on it and the transmission was rebuilt around 170,000
  2. Jun 28, 2017 at 8:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Driveshaft U joints and center bearing for excessive play, maybe
    STEVEO13016[OP] likes this.
  3. Jun 28, 2017 at 8:58 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I have a 2005 so second gen but I had this issue, the shifter would even slip into neutral while driving. I lubed up this piece in the side of the trans that connects the linkage to the trans. 2 years later she's perfect!
  4. Jun 28, 2017 at 8:59 AM
    STEVEO13016
    STEVEO
    Center bearing is worn out… Probably explains why I have a little bit of a wobble as I get above 50 to 60 mph… I will work on replacing that first… I also did the same thing and lubed up the shifting moving parts next to the transmissions… Instead of lube or used silicone spray
  5. Jun 28, 2017 at 1:41 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Also, check your mounts for movement?
