Shifting into neutral kills tranny! What?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KENNESAWTACO, Apr 7, 2010.
  1. Apr 7, 2010 at 1:32 PM
    KENNESAWTACO
    KENNESAWTACO [OP] Member
    KENNESAW, GA
    2013 Prerunner, TRD Sport
    Flowmaster super 44, anytime foglight mod, K&N highflow air filter, removed front mud flaps
    From time to time (esp when gas hit a all time high) I bump my auto trans into neutral when coming up to a red light or going down a good size hill. Mainly to save on gas and/or brakes.
    Well I went into the dealership today to ask if they have a re-flash or TSB for the 2008 Taco's. And of course the service writer had no idea what I was talking about, Tacomas have never had tranny issues. So I tell him all the mis-shifts, searching gears, & holding gears issues I have. And that the searching for gears happens when I use N down hills or sitting at a light.
    He tells me that shifting into N will void my tranny warranty. Something about the tranny that it loosing suction and kills the insides if done for more then a collective 9 miles. Set appt for tomorrow to reset the 9+ miles back to 0
    Anyone else ever hear or been told this before?
  2. Apr 7, 2010 at 1:41 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I don't think the fluid is moving if it is in N, something like the pump is not working when in N.
  3. Apr 7, 2010 at 1:42 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I've heard of this before. I think the pump for the tranny fluid is on the front of the tranny meaning it has to be spinning with the engine to be getting lubricated so that would be basically starving the tranny of fluid.
  4. Apr 7, 2010 at 1:43 PM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    When did they include the 2008's in the TSB? I thought it was just the 09-10's.
  5. Apr 7, 2010 at 1:45 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I wander if it is hard on 6 speeds as well? I shift into N all the time when coming to a stop sign.
  6. Apr 7, 2010 at 1:45 PM
    Jason'sLawnCare
    I don't think it affects the manuals. Where's Chris he knows this stuff.
  7. Apr 7, 2010 at 1:48 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ^^^^^^ I'm guessing because of the shitty shifting issues he mentioned that the reflash addresses.
  8. Apr 7, 2010 at 1:50 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Manual has no pump, the gears just slosh around in the fluid.
  9. Apr 7, 2010 at 1:55 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I don't see how it would matter if the fluid is moving or not. If you are in Neutral there is NO mechanical linkage is there?
    And if the pump is in the front, then it would be moving with the engine at all times. I just don't see any reason that it would screw up a transmission.
    Furthermore, how many automatic pick-up trucks have you seen towed using a front wheel dolly? They have to put the truck in N in order to tow it. I call BS on it man.
  10. Apr 7, 2010 at 1:58 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Engine would be off. Heat would be a non issue I should think. Otherwise you wouldn't require towing.
  11. Apr 7, 2010 at 1:59 PM
    Jester243
    Dan
    Spokane, WA
    Here is quote from Chris:
    this is from: http://www.tacomaworld.com/forum/technical-chat/59600-neutral-gear-faster-than-drive-gear.html
  12. Apr 7, 2010 at 2:02 PM
    Jason'sLawnCare
    Your tranny is still connected to the drive shaft right? When they are on a front wheel dolly I'm almost positive that the drive shaft is supposed to be unbolted.
    Check this out go to the precautions.
    http://www.pensketruckrental.com/personal_rental/accessories/towing_tow_dolly.html
  13. Apr 7, 2010 at 2:06 PM
    Afwrestler1986
    Johnstown, NY
    I realize the tranny is mechanically linked to the drive shaft, when in Neutral the back half of the tranny is not linked to the front half mechanically is it?
  14. Apr 7, 2010 at 2:08 PM
    Jason'sLawnCare
    Are you saying the drive shaft isn't linked to the engine? I'm a little confused. Just check the link obviously there's a problem towing rear wheel drive cars with the drive shaft in place on a dolly.
  15. Apr 7, 2010 at 2:09 PM
    Jason'sLawnCare
    The engine isn't the only thing that produces heat in a vehicle. I'm not trying to be a smart ass but have you heard of a transmission cooler?
  16. Apr 7, 2010 at 2:10 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Here's my question, if the tranny overheats while coasting in neutral, then what are you supposed to do WHEN YOUR GAS PEDAL STICKS!?!?!?!
    Jesus christ the Japanese hate us...
    EDIT: Sarcasm implied
  17. Apr 7, 2010 at 2:12 PM
    Jason'sLawnCare
    I think you have bigger worries if your pedal is stuck than a transmission failure but you could just turn the engine off and flip the key back to the on position I would think.
  18. Apr 7, 2010 at 2:12 PM
    Jester243
    Dan
    Spokane, WA
    :confused:
  19. Apr 7, 2010 at 2:15 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    my question would be which side of their asses did they pull the 9 miles thing from....and also if it is a mechanical issue w/ going a collective 9 miles in N, how can it be reset? it intentionally grenades at the 9 mile mark unless the trip meter on it is reset?
  20. Apr 7, 2010 at 2:15 PM
    Afwrestler1986
    Johnstown, NY
    If you are in Neutral going down a hill, your tires are moving much faster that what your engine is right? Because you remove the engine's resistance from the equation. Unless an auto tranny is different. I have never delved into the realm of auto's. But it would make sense to me that when in D, R, or P that there is a mechanical linkage to the engine. When in N there is not.
    The tranny burning up makes sense, but it seems like another reason to get a manual. :D
