Shifting issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by murphy30547, May 9, 2012.
  1. May 9, 2012 at 6:28 AM
    murphy30547
    murphy30547 [OP] New Member
    Georgia
    98 Tacoma
    LCE Clutch, LCE header and cat-back.
    Hello all,
    I bought a 98 tacoma 2.4l 2wd xtra cab manual transmission last weekend and I love it. The thing is that the transmission is unusually hard to shift without a little bit of grinding. I have driven manual transmissions for 17 years now and never had this many issues getting used to a new one. I started out shifting by pressing the clutch all the way in and still got a gear tap on 3rd and a nice grind on 4th. Then a friend suggested I press the clutch half way (which is hard to remember to do) and it helped a little, but I can't even drive a couple of miles without grinding in 3rd or 4th. I have driven cars and trucks with bad clutches and messed up transmissions and never had one where i have to use strategy to be able to shift. It's very rare to have a nice clean set of shifts up to 5th when i am driving. I have tried let off the gas and waiting a few seconds then shifting(normally ill let off the gas and depress the clutch at the same time.) The clutch was replaced with an LCE one a few 1000 miles ago, the clutch pedal is nice and tight with about 1/2" free play at the top, and if it may help anyone with diagnosing the pedal is a little higher up than the brake pedal is that normal? I love the truck and I would just love to be able to drive it without shouting choice words when it grinds for no apparent reason. Is there anything that I can do to fix this issue? Thanks.
  2. May 9, 2012 at 8:51 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    First of all, welcome to TW!
    You covered about every question I was going to ask. The problem may not be the pedal at all. Maybe your syncros are bad? I am kind of at a loss.
  3. May 9, 2012 at 10:26 AM
    murphy30547
    Georgia
    98 Tacoma
    Roger that I will have to give that a try. Then I'll go from there. Thanks for the welcome.
  4. May 9, 2012 at 12:44 PM
    murphy30547
    Georgia
    98 Tacoma
    That was a no go, very little air came out and didn't make a difference on driving. I noticed the boot on the slave was rather ragged and the fluid was very dark. And slimy looking, might pick up a slave, and also some royal purple for the transmission and gear box. Oh btw is bleeding the clutch done with the engine running or off I had it off cause I thought that's how you do brakes. Thanks
