Shifting Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hog4fun, Mar 23, 2021.
  1. Mar 23, 2021 at 5:12 PM
    Hog4fun
    Hog4fun [OP] New Member
    Doug
    19Tacoma
    Lift and tires
    I have a 2019 Taco and just did a long rode trip thru Texas. While on flat roads the shifting between 5-6th gears was annoying. It could not hold 75 with the cruise on and would keep down shifting to 5th. Any one else have this issue?
    tacoman45 likes this.
  2. Mar 23, 2021 at 5:25 PM
    N5J_Taco
    N5J_Taco Well-Known Member
  3. Mar 23, 2021 at 5:25 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Ha this is a pretty common issue. It's just the programming logic of the transmission to try to get the truck to meet EPA req's.
    If you find a good dealership, you might be able to have them flash your ECU using TSB 0092. Should sort out your issue for you.
  4. Mar 23, 2021 at 5:30 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard
  5. Mar 23, 2021 at 5:31 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    It's how it is...
  6. Mar 23, 2021 at 5:55 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    Use ECT and Sport Mode, it helps a bit.
  7. Mar 23, 2021 at 5:58 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    Get someone to put OVtune on your truck. Should run you $250 and make the truck much, much better.
  8. Mar 23, 2021 at 6:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Common, 5th and 6th are both overdrive gears,,, it's tuned to make the big GOV and environmental agencies happy,,,, not you. As are every other low torque engine, 6-10 speed transmission truck.
    Often folks are comparing a modern vehicle, to their 10-15 yo vehicle,,,,, times they are a changin
