shifting problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotaforlife08, May 20, 2010.
  1. May 20, 2010 at 5:38 PM
    yotaforlife08
    yotaforlife08 [OP] Well-Known Member
    Justin
    Wells,ME
    08 Tacoma,SR5
    bilstein 5100's and tons of dee zee spray on bed liner.
    so my truck is headed to the dealership tomorow. i went outside and turned my truck on and none of the gear lights turned on so i went to shift and it wont shift had to use the the electronic disingauge button and shift it that way the dealership says there stumped this should be intresting, this happen to anyone else??????:confused:
  2. May 21, 2010 at 5:17 AM
    BCTacoma2010
    BCTacoma2010 Michigan Member
    Jay
    Southwest Michigan
    2010 TRD Sport Access Cab
    Do you have brake lights? I've seen a loose or bad brake light switch cause this issue.
