Shifting to neutral w/o clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Aug 31, 2018.
  1. Aug 31, 2018 at 1:34 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    I've read some mixed opinions from various forums regarding this. When rolling up to red lights/stop signs in 3rd or 4th gear, I have a habit of letting the engine brake until the RPM's match a low enough rev that the gear slides into neutral with no effort. In my mind, I do this to save wear on engaging/disengaging the clutch. I know it's minor but small things add up over time (especially something as frequent as clutch use). I'm reasoning that if it slips out of gear w/ no effort it's perfectly safe since there's no load between the engine and transmission, at least that's how I make sense of it in my head.
    What I want to know is whether or not this is damaging or unnecessarily wearing any parts. What are your thoughts?
    TXpro4X4 likes this.
  2. Aug 31, 2018 at 1:39 PM
    Fuelman
    Fuelman Well-Known Member
    Winchester VA
    2014 Taco DCLB Sr5 4x4
    Ultraguage
    As long as you are not forcing or grinding no harm no foul. Most truckers never use the clutch except to change direction or get it in gear when stopped.
    REDdawn6 and stomachbuzz like this.
  3. Aug 31, 2018 at 1:49 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    I do that too. Rev matching on downshifts also help
  4. Aug 31, 2018 at 1:52 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I power shift my F350 from 3rd to 4th and let off throttle and slip out of gear all the time.
    My 88 and 99 Toyotas with 5 speed took all the abuse I gave them for 170k + miles.
  5. Aug 31, 2018 at 1:57 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I do it from time to time.
    But my clutch has 130,000 miles on it I've put it thru some shit although on a regular I'm not hard on it. So idk. Choose your battle I guess. Good luck.
  6. Aug 31, 2018 at 2:06 PM
    2017 Oregon Tacoma
    2017 Oregon Tacoma Well-Known Member
    Michael
    Oregon
    2021 Tacoma Off-Road
    good question as I do this all the time and never thought twice about it... Same reason I thought it might give some extra life to the clutch :D
    Vrbas[OP] likes this.
  7. Aug 31, 2018 at 2:52 PM
    Vrbas
    It's not making any crazy noise or offering any resistance, so I just assume it's not harming anything. Then again, just because I don't get negative feedback doesn't mean it's not bad for it. Maybe it wears on the synchro bearing??
  8. Aug 31, 2018 at 7:33 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Truckers do it because the big truck gears are "straight cut" where they can upshift as well as downshift. As long as its at the right rpm i don't see an issue with it. I'm not sure on the taco trans but a lot of newer cars have a carbon lined synchros where one forceful move can remove the carbon lining. I've always been under the assumption that its fine as long as you don't mess up
  9. Aug 31, 2018 at 7:45 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    I do it all the time, 130k on the clock.
    As long as you aren’t forcing it out of gear and there’s no load on the cogs, I don’t imagine yer hurting the whirley bits. But I’m a simple minded bumpkin who don’t know much about nothin.
    BassAckwards likes this.
  10. Sep 1, 2018 at 6:09 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Had a '71&'76 Mercury Capri. Blew the clutch up on the '71 and drove it 2 weeks before fixing it. If you match the rpm change between gears, it'll slide right in. When downshifting, blip the throttle to a little higher than what the rpm change would be.
    I'd also do this in the other Capri and the '94 ranger. Just bc I could. I say if it's not grinding, it's not a problem.
  11. Sep 3, 2018 at 10:33 AM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    I use the clutch on my 08 simply for taking off and going from 1st to 2nd. With a blip of the throttle you can downshift just fine and upshifting is a breeze. Like they said as long as it slips right in there shouldn’t be an issue. 110,000mi on the clutch I bought the truck with. And still feels as strong as when I bought it.
  12. Sep 3, 2018 at 10:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've got 184k on the original clutch and never do this. I always clutch in and out when changing gears or pulling it out of neutral. So I don't think you're necessarily saving the clutch and possibly putting extra wear on the synchros. I'd rather put wear on the clutch (a replaceable wear item) vs the synchros (I have no idea if those are easily replaceable).
    TireFire likes this.
  13. Sep 3, 2018 at 7:15 PM
    Vrbas
    Can you walk me through how you shift out of gear without using the clutch once you're rolling? As mentioned in my original post, I only slip it in and out when I'm low-speed rolling; I can't begin to think how to do this at regular get-up speeds.
  14. Sep 4, 2018 at 5:00 AM
    jfoster92
    Justin
    Farmerville, la
    You want to go into neutral as your coming off the throttle. It should take little to no effort. If you wait till your completely off the throttle there’s to much of a bind on the transmission as your in an engine braking scenario. I hope that explains it well enough.
  15. Sep 4, 2018 at 8:23 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    While my Tacoma is an automatic, I've owned many MT vehicles (including my current Corvette) and always done this... never had a problem.
    Larzzzz likes this.
  16. Sep 4, 2018 at 10:40 AM
    Vrbas
    Thanks, I'll have to give this a try. I am fearful of damaging things though because I'm a clumsy MF
  17. Sep 4, 2018 at 1:47 PM
    jfoster92
    Justin
    Farmerville, la
    It might take a few tries to get it down but if it’s something you’d prefer to do go for it. I wouldn’t try to mimic anyone’s driving style unless you feel like it’s an improvement over your own. Do what your comfortable with and just enjoy your truck.
  18. Sep 4, 2018 at 1:59 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Same here @ 159k
    EatSleepTacos[QUOTED] likes this.
  19. Sep 5, 2018 at 1:16 PM
    Larzzzz
    Larry
    MA
    Before you try, watch the rpm change on the tach when shifting, it may be the same change for each gear, it may not. That will get you in the ballpark of where the engine needs to be for it to slip into gear.
    Timing... Practice popping it into neutral. You'll see where in letting off the gas it pops out easiest. Your letting off the gas, letting it drop to the shift point so you can side it in to the next gear and step on the gas again
    It's easier imo to downshift. When in neutral, blip the gas to a little higher than what the rpm change would be and it slides right in.
    Like anything, it takes practice. If i can do it, you can...:thumbsup:
  20. Sep 5, 2018 at 1:31 PM
    Vrbas
    Thanks, yeah I've been able to fumble my way through it a couple of times. I'm having more trouble pulling it out of gear into neutral [to prep for next upshift] rather than rev matching into the next gear; just easier to blip the throttle and apply light pressure to find where it'll slide in w/o resistance. Just finding that sweet spot b/t foot on accelerator and foot off accelerator.
    For whatever reason, 2nd to 3rd is giving me the most trouble pulling into neutral. 2nd gear seems to have the tightest grip/smallest window. It's also awkward and clumsy doing all this in traffic because it's not the smooth transition that utilizing the clutch offers (guess that's why they saw fit to include a clutch, eh?). Nonetheless, practice makes better (not perfect in my case) so I'll keep playing with it. I'm not trying to make a habit out of it, but it's a technique I'd like to be somewhat proficient at in case the need were ever to arise... also just to impress people because that's what really matters in life.
    jfoster92 likes this.
