Shifting wierd at low speeds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Sep 17, 2020.
  1. Sep 17, 2020 at 7:51 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Mine had the same symptom when it was new. Noticed it more when it was cold. My tranny fluid came from the factory a quart low and I had Toyota do the TSB on transmission software for the 2016s. Not sure what cured it, but it does not do it any more. Try to get a video of the RPM rev, in case you can not make it happen for the tech when you take it in.
  2. May 24, 2023 at 11:06 AM
    Taco19offroad
    Taco19offroad Member
    19 tacoma off road
    Mine does it also 2019 tacoma off road automatic transmission coasting to a stop light at times and goes green and I'm not completely stopped i press the gas to keep moving it revs a few hundred rpms quick and jerks into gear also rolling slow down a alley or slight hill other wise its fine shifts great through all the gears doesn't happen all the time but when it does I get annoyed with it! I've had a transmission flush and told then to check the fluid they said it was normal level not low so I dunno unless it gets confused at times it being a artificial intelligence computer trying to figure out what ima do next
    VB25, JohnAndrew and Zuba Gooding Jr like this.
  3. May 24, 2023 at 9:36 PM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    Same here. Like a dead spot in pedal when coasting at low speed. Worse when making a turn rolling downhill.
    Taco19offroad, VB25 and Schlong like this.
  4. May 24, 2023 at 9:41 PM
    Schlong
    Schlong not your average stoner
    York, South Carolina
    2019 Tacoma SR5 2x4
    Stawk
    Always have to check and make sure I didn’t just run over a flock of geese crossing the road…
    Happens to me in the same spot every day coming home from work in traffic. I’ll be coasting about 15-25 mph and it’ll have a complete stutter attack at least 3 times on my way home
  5. May 25, 2023 at 5:51 PM
    JohnAndrew
    JohnAndrew New Member
    2023 Tacoma SR V6 4x4
    I'm glad you guys revived this thread, this is the most relatable comment I've read in a while. My 2023 acts so weird and don't want to be that guy at the dealer. Before the truck I drove RAM high roof van 2500 (6 cylinders). I knew this would be different but feels very strange. In my van (automatic) I would manually downshift on hills. When I did it a bit too early I would experience the same jerk.The tacoma feels like its shifting at the wrong time, all the time. There are several spots in my daily commute I can replicate the issue you're describing.
    T-yoda[QUOTED] and VB25 like this.
  6. May 26, 2023 at 4:59 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I can't recall if my sr5 ever did that when new, but I can tell you it's a very normal running truck now. I don't think you can make it shift any better, or more precise.
    T-yoda and VanGo3 like this.
