ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Jan 28, 2018 at 2:46 PM
    #2061
    deadgame
    deadgame Well-Known Member
    2017 Tacoma TRD Pro
    Best place to get the info for sure!
    Frito[QUOTED] likes this.
  2. Jan 28, 2018 at 5:38 PM
    #2062
    TRDFirewalker
    TRDFirewalker New Member
  3. Jan 29, 2018 at 7:55 AM
    #2063
    Spider171
    Spider171 Well-Known Member
    18 Trd Off-road Cement LB
    How does it work with push start? Any issues changing modes?
  4. Jan 29, 2018 at 8:19 AM
    #2064
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Not sure why push start would change anything??
    JoeWillie likes this.
  5. Jan 29, 2018 at 8:32 AM
    #2065
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    It works fine. It only engages once you go into "S" mode.
  6. Jan 29, 2018 at 10:14 AM
    #2066
    Jrobb
    Jrobb Well-Known Member
    Jon
    SF Bay Area
    2017 Double Cab Lb SR5 Magnetic Grey Metallic
    It differs in how you turn on the ACC without starting the car. If memory serves, you have to turn off the engine and have key in ACC position or pushbutton in ACC mode to program the 1, 2, or 3 shift map...if you want to change it.
    J
  7. Jan 29, 2018 at 10:26 AM
    #2067
    Taco16LB
    Taco16LB Well-Known Member
    I believe it needs to be in the start position . without foot on brake- push the start button 2 times , you are now in the start position , put shifter in S mode ,wait 10 seconds to here the beep or beeps , then shift up or down and count beeps to know what mode you are in , keep shifting one time one way or another ( listen for beep/beeps )to change and listen for how many beeps there are.
    EDITED -Hard to explain but it does work with a push button truck . The instructions come with the SSP for push button start trucks .
    okccj and Spider171 like this.
  8. Jan 29, 2018 at 1:22 PM
    #2068
    Spider171
    Thanks Taco16lb that's exactly what I needed to know. I've only had it a month and sounds dumb but didn't know that is how accessory works. I was seriously thinking, about trading it because the transmission really sucks. I am getting crap fuel economy, barely better than my 13' Tacoma that had 86000 miles. I loved that truck, hated the fuel economy and was told the 3rd gen ones are a lot better.
    Taco16LB likes this.
  9. Jan 29, 2018 at 1:47 PM
    #2069
    Taco16LB
    You will not be sorry !!!!!
  10. Jan 29, 2018 at 2:16 PM
    #2070
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    Wanted to chime in. I was order 1006. I now have 15k on the Shiftsense and I can’t imagine life without it. Just the other day I threw it in D on a route I take every day and the difference was immense. The shiftsense make the truck drive like it should have from the factory. Zero problems with any features. Great job guys.
    Frito and IndyFastlane like this.
  11. Jan 29, 2018 at 6:36 PM
    #2071
    TRDFirewalker
    No issues. I have a push start.
    Frito likes this.
  12. Feb 1, 2018 at 12:53 PM
    #2072
    Rgbot2324
    Rgbot2324 Member
    Raleigh, NC
    2017 White TRD
  13. Feb 2, 2018 at 6:49 AM
    #2073
    snozberries
    snozberries is forever trying to find a campsite
    Cory
    Martinez, CA
    2016 Quicksand
    Tires, Rack, LED bar, RTT, etc.
    So I am having a small issue, not sure if I'm missing something. Installed fine and I know the unit is working. When I try to get to program mode, I never hear the long beep. Upon trying to change the mode, I only get 3 beeps and then nothing when trying to go down or up.
  14. Feb 2, 2018 at 7:23 AM
    #2074
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You are following these instructions?
    https://www.tacomaworld.com/threads...for-gen3-tacoma.490113/page-103#post-16840678
  15. Feb 2, 2018 at 10:07 AM
    #2075
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Sounds like you have the truck started. Engine has to be off.
  16. Feb 2, 2018 at 10:08 AM
    #2076
    snozberries
    Cory
    Martinez, CA
    2016 Quicksand
  17. Feb 2, 2018 at 2:31 PM
    #2077
    Spider171
    Order#1950 I hope it's as easy and good as everyone says. My wife was complaining about how my truck shifts on a short drive yesterday! She complains when I say about upgrading anything, I guess another ride after I get it installed and then I'll drop the bomb!
  18. Feb 2, 2018 at 2:36 PM
    #2078
    Spider171
    Also a 1500 mile trip to Daytona next month towing a enclosed trailer with 2 Buell's and a bagger. I was worried about the trip, 1200 miles on my truck. I am going to give her a real workout! Any thoughts?
  19. Feb 2, 2018 at 3:40 PM
    #2079
    Frito
    Frito Well-Known Member
    Are you coming from Hill Country or are you a Flat Lander ?
    I'd work hard to at least doublie those miles before the trip and then some....
  20. Feb 3, 2018 at 8:36 PM
    #2080
    Frito
    Been riding around in Mode 2 for a few days now thinking the SSP was pretty good.
    I almost forgot about the ECT button down there on the dash, till tonight on the way home.... WEEE-OOO ! :cool:
    Can't wait for the sun to come up and go out and try this some more.....
    After I forget all the niggling little stuff, maybe I really can learn to like this truck after all ? :fingerscrossed: Thank You SSP !
    gulzeb likes this.
