ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Mar 3, 2018 at 8:46 PM
    #2181
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Yeah, we’re all idiots. Thanks for letting us know.
    freedomriding likes this.
  2. Mar 5, 2018 at 2:25 PM
    #2182
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    Is this your 1st Toyota and/or Tacoma? You'd only know that this 3rd gen transmission is garbage if you answered yes because we're comparing it to the previous generation Tacoma, or hell, any generation Toyota for that matter
  3. Mar 5, 2018 at 3:13 PM
    #2183
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    If I'm still having an issue with my Tacoma hanging in fourth/fifth with Shift Sense Pro (Program 2) installed, what could this be caused by? Transmission fluid?
  4. Mar 5, 2018 at 3:19 PM
    #2184
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Does it hang after coolant has come up to temp?
  5. Mar 5, 2018 at 3:20 PM
    #2185
    Rocky.Mtn
    Canada
    Yes sir. It happens generally on the highway where the truck seems to be revving high for the speed (twitchy throttle) and won't kick down.
  6. Mar 5, 2018 at 3:37 PM
    #2186
    splitbolt
    NW Arkansas
    ECM
    Engine coolant temp sensor
    Valve body
    No. 3 brake (B3)
    SL1 solenoid ON malfunction
    Transmission fluid
    Does it have any other funky behavior?
  7. Mar 5, 2018 at 4:28 PM
    #2187
    IndyFastlane
    IndyFastlane Well-Known Member
    When this happens, try lifting slightly on the throttle. This will signal to the SSP to upshift. From what I was told by the OP, this is by design so that you can keep/hold 4th to continue accelerating or lift slightly to indicate to SSP that you are going to hold speed and cruise. Took some time to get used to.
    FWIW, this is not as noticeable in program #1.
    Jukeboxx13 and Rocky.Mtn[QUOTED] like this.
  8. Mar 5, 2018 at 5:05 PM
    #2188
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    7th
    Edit: Actually 6th my 1st was a Toyota Pick-up.
    freedomriding[QUOTED] likes this.
  9. Mar 5, 2018 at 6:10 PM
    #2189
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I have had a plenty of vehicles, and I have never hated a transmission before this. A 3-speed-auto would be better than this.
    OkieCowboy likes this.
  10. Mar 5, 2018 at 6:31 PM
    #2190
    Rocky.Mtn
    Canada
    Nothing that I would say is more noticeable than the fact at hand! Is there something else I should be looking at? My thought was Transmission Fluid, but I don't know if this actually could be linked?
    Will try Program #1.
  11. Mar 5, 2018 at 7:00 PM
    #2191
    splitbolt
    NW Arkansas
    I mentioned all that other stuff because you made it sound like it was happening prior to installing the SSP.
    In 11,000 miles, I've had upshift hang in 4th on the highway several times using SSP; could not modulate it out with the gas.
    I've also noticed, if I switch from SSP S-mode to D and back to SSP S-mode, it won't upshift out of 4th; again, no matter how I modulate the gas.
    I just chalked it up to the stock S-mode shift pattern overriding the SSP. Then again, I never noticed it do that in S-mode the 10,000 miles prior to using SSP. I've pretty much avoided D from day one.
    Rocky.Mtn[QUOTED] likes this.
  12. Mar 5, 2018 at 7:06 PM
    #2192
    Rocky.Mtn
    Canada
    This is exactly what I'm seeing. The difference that I see it quite regularly where the upshift just won't. Even if I shift into "D" and back to SSP it would continue to hang.
  13. Mar 5, 2018 at 7:08 PM
    #2193
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    SSP does not engage above 60 mph for safety reasons. So if you’re switching to D and back to S going above 60mph, you’ll be in S4 mode, with SSP off.
  14. Mar 5, 2018 at 7:15 PM
    #2194
    splitbolt
    NW Arkansas
    I wasn't above 60 mph...and the safety is 65 mph.
    gulzeb[QUOTED] likes this.
  15. Mar 6, 2018 at 5:26 AM
    #2195
    OkieCowboy
    OkieCowboy Well-Known Member
    Lloyd
    Choctaw, Oklahoma
    2012 TRD 4X4 Access Cab
    Agree. Or even the old two speed Powerglide.
    I got heartburn every time I looked at the Tacoma ONLY because of the transmission. The SSP has certainly helped. I keep reading about the OV Tune and am seriously considering investing in that. I want the constant shifting to stop at highway speeds and to be able to use the cruise control. Too many hills in eastern Oklahoma and now WIND. We are to have sustained winds of over 30 mph and gusts up to 60 mph today.
  16. Mar 7, 2018 at 6:58 PM
    #2196
    Neoturner
    Neoturner Large Member
    Turner
    Atlanta
    2016 Black SR5 DCSB 4x4
    Sigh. Another day, another mod I didn't know existed.
    Sigh...
    :spending:
  17. Mar 7, 2018 at 7:40 PM
    #2197
    Murphystaco
    Murphystaco Well-Known Member
    2017 white Tacoma OR
    This will be worth every penny. Wait for one to show up in the parts for sale forum and save some coin you wont be disappointed
    Neoturner[QUOTED] likes this.
  18. Mar 7, 2018 at 8:56 PM
    #2198
    Neoturner
    Turner
    Atlanta
    Too late.
  19. Mar 8, 2018 at 5:27 AM
    #2199
    OkieCowboy
    Lloyd
    Choctaw, Oklahoma
    We were going to Tulsa yesterday in the CR V on the turnpike. I had the cruise set at 83. (I can actually use it in this car). Changed lanes to pass with nothing in the rear view mirrors. Then bam, there was a third gen Tacoma so close I couldn’t see his bumper. I sped up and moved out of his way as soon as possible because I know he didn’t want that damn transmission to gear down.
    Jukeboxx13 likes this.
  20. Mar 8, 2018 at 10:36 AM
    #2200
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    My ssp makes this crazy electronic squicky noise when I first start the truck up. Is this normal?
