ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 8, 2017 at 8:46 PM
    #221
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Nice job explaining...
    I'm guessing this is on the other side of "D+ECT" rather than between D and D+ECT otherwise there'd be no reason for it.
  2. May 8, 2017 at 11:43 PM
    #222
    kupaa1
    kupaa1 Well-Known Member
    Hawaii
    2016 Tacoma TRD Sport Access Cab
    Sounds like a great product.. lets see some reviews.
    Oldman808 likes this.
  3. May 9, 2017 at 3:59 AM
    #223
    tacogeorge
    tacogeorge Well-Known Member
    George
    2016 Tacoma TRD Off Road
    Disclaimer: I don't own this product but I did read this thread and glanced through the other thread referenced and I'm gonna take a stab at a few things I've seen. OP or other competent authorities feel free to correct me.
    No, this is not going to lock you into 6th gear on the highway. The OP stated that this device is programmed for a shift to 6th somewhere around 77 mph, assuming you aren't still heavy on the throttle. With this product installed, you will almost never use 6th gear. I can guarantee your mpg will take a hit but the whole point of this thing seems to be to override Toyota's decision to prioritize mileage over performance, so no surprise there. If you aren't sure how you feel about virtually never using 6th, try driving on the highway in S-5 for awhile. Not a perfect demo but it seems to me that for normal highway cruising (60-70mph) the only difference between S-5 and this gadget is that the truck should be more willing to downshift to 4th with the ShiftSense installed.
    I don't think so. In the development thread the OP called the ECT shift points sloppy and overly aggressive. I think the idea here is a new normal mode. Your normal Drive gear essentially becomes eco mode and ECT is still the fun button. It doesn't seem to be aimed at the Ricky Bobby crowd. I think this is for the guys that hate the way the truck will shift to 4th around 35 miles per hour if you aren't heavy on the gas trying to get on the highway. Then you're bogged down and have to mash the gas enough to catch 3rd Or the way you'll be cruising in 6th gear on the highway and the cruise control decides you need to shift to 5th to make it up a tiny hill, but then by the time it downshifts it has dropped another 2 mph and thinks that it now needs 4th gear to regain the whopping 3mph that you've lost from going over an overpass.
    I am waiting to see some reviews on this but it certainly seems like it has potential to be awesome. I've messed with S-mode shifting very little in this truck so while I patiently await reviews I'm going to drive around a bit and mess with it myself, to include a few highway trips limited to 5th and see how I like it.
  4. May 9, 2017 at 4:11 AM
    #224
    Clearwater Bill
    Billy
    Largo Florida
    I understand why folks would ask questions, but the 'inventor' has given good explanation of the development process and design principles.
    If I had one of the annoying 3rd Gen transmissions, I'd be instantly dropping the <$200 and 15minutes of install time. That's nothing when I have a $35k truck that can't make up it's mind and Toyota can't fix it. Many people around here drop that on a 'level lift' and 2x that on a 'pro grill', neither of which 'do' anything.
    With it's ease of installation, I'd be removing anytime I went to the dealer. Just because they don't need to question it, regardless of why I was there. Shoot, I already pull off my trim rings, center caps and fancy valve caps when go to have tire work done. This thing would be faster than that. :thumbsup:
    @dcz108 , hoping everything works well for you! Maybe Toyota will come knocking and want to buy your map! :D
    Idig63 and PMG like this.
  5. May 9, 2017 at 5:24 AM
    #225
    PMG
    PMG Well-Known Member
    Bethpage, NY
  6. May 9, 2017 at 5:50 AM
    #226
    Taco16LB
    Taco16LB Well-Known Member
    This exactly my take on this also .
    tacogeorge[QUOTED] likes this.
  7. May 9, 2017 at 6:01 AM
    #227
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
  8. May 9, 2017 at 7:06 AM
    #228
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    For those concerned about spending $175, just don't buy Starbucks for a month and you'll have enough money to pay for it. If you don't like it then think of how much time you saved from standing in line or waiting in the drive-thru. $175 is nothing for all the complaining that goes on about the shifting. It might just be the best $175 you ever spent.
    TurnLeft, treimche, Jorge3098 and 2 others like this.
  9. May 9, 2017 at 7:13 AM
    #229
    Cavedog
    Cavedog Well-Known Member
    Eric
    Southern Minnesota
    2016 MGM AC Sport 4x4
    @dcz108 Will the box potentially fit under the center console on the back of the cup holder plastic extrusions? No offense but it is absolutely monstrous and kinda ugly. Also- to prevent any dealer/warranty conflicts I plan on either removing or hiding the unit every single time I bring it in for service (and unplugging/hiding the obdII plug). Yes, yes, I know about Magnuson-Moss but not all dealers share your viewpoint and I'd rather just avoid the issue entirely.
  10. May 9, 2017 at 7:32 AM
    #230
    Howanic
    Howanic Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    Starbucks is shit coffee anyways.... the $175 isn't bad at all for quality of life changes to your truck, how well it works without any hiccups is the question and warranty issues of course.
  11. May 9, 2017 at 7:57 AM
    #231
    PMG
    Bethpage, NY
    But I love me my fraps bro..
    All kidding aside. I will also remove the until every time I'll take it into service. If by any chance something happens to the transmission down the line first thing they'll say is that the shiftsence put to much strain on the transmission and bla bla bla bla bla :jerkoff:
    treimche likes this.
  12. May 9, 2017 at 8:07 AM
    #232
    davidsp101
    davidsp101 Well-Known Member
    David
    Columbia, SC
    2017 TRD OR 4x4
    Anyone have any insight on how this might improve the rough downshifting when coming to a stop?
  13. May 9, 2017 at 8:56 AM
    #233
    Cavedog
    Eric
    Southern Minnesota
    It has nothing to do with that; this system is literally the exact same as shifting from S1-S6 on your own, it just has predetermined shift points.
  14. May 9, 2017 at 9:14 AM
    #234
    davidsp101
    David
    Columbia, SC
    2017 TRD OR 4x4
    Yeah, I get that but the OP said that it has specified downshifting points too. My truck will decide as I'm coasting between 10-15 mph that it needs to slam down into 2nd gear if it was previously in a higher gear. Especially evident in stop and go traffic.
  15. May 9, 2017 at 9:21 AM
    #235
    Cavedog
    Eric
    Southern Minnesota
    I thought you were referring to the "rumble strip" feel some people experience. As far as just downshifting, I think you're right. I sure would like to test drive a truck with this in it to see how it works before buying one.
  16. May 9, 2017 at 9:30 AM
    #236
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    Mine is now due here on Thursday according to the USPS. It'll get installed immediately as I have a trip to Houston this weekend and I want to see how it does on the highway. So hopefully early next week I'll have some insight about it to share. I unfortunately have to rip it right back out on Monday night because the truck is headed to the dealer to initiate rear-diff gasket replacement on Tuesday.
    Swiftks likes this.
  17. May 9, 2017 at 9:34 AM
    #237
    Clearwater Bill
    Billy
    Largo Florida
    Make sure they have the parts in hand and know what they are going to do before taking it in. So it doesn't get held hostage while they try to figure out what to do regarding the recall, as some have reported around here...........
    Krucen 01 likes this.
  18. May 9, 2017 at 9:45 AM
    #238
    backtrack2015
    Austin TX
    Yes my service-advisor and I already talked that through. They promised my truck won't be held hostage since it isn't part of the recall. Thanks!
    Clearwater Bill likes this.
  19. May 9, 2017 at 9:49 AM
    #239
    Drakedischler1
    Drakedischler1 Well-Known Member
    Houston, TX
    2016 TACOMA TRD OFF ROAD QUICKSAND
    3" LIFT , 305 70 16 TIRES
    Ahh what the hell . Order placed !
  20. May 9, 2017 at 10:17 AM
    #240
    TortillaSupreme
    TortillaSupreme Member
    Neil
    Same here. Was gonna wait for reviews but tough to wait it out haha. Thanks for putting this together!
