ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 10, 2017 at 2:59 PM
    #281
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    All of this has been discussed and answered.
    S4.
    Yes, 1-6.
    kgilly and FrankJake[QUOTED] like this.
  2. May 10, 2017 at 3:30 PM
    #282
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    What you said isn't necessarily true. If you are stopped and go from D to S4 it doesn't start you out in 4th gear. It'll go 1,2,3,4 exactly like it does in D even if you have it in S4 the whole time. What it won't do is go to 5th or 6th when it would have in D.
    With the box when you go from D into S mode it will go into whatever gear it deems appropriate based off what it reads from the OBD port. Look at the shift maps above to see what gear it would go for with X speed and X gas pedal. And yes it shifts automatically through all gears.
    mokeiko and FrankJake[QUOTED] like this.
  3. May 10, 2017 at 3:38 PM
    #283
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    Yes, the initial shift into S goes into S4 (or S3 in rare instances) but the device knows this and will immediately index it up or down from there based on the engagement speed. If stopped when you engage it, you will see it shift down to S2, which is the lowest selection provided by the device. Even though you may see S2 on the dash, the truck will still start out from a stop in 1st (S sets upper limit). The reason for not going all the way down to S1 with ShiftSense is because the shifts between 1 and 2 are heavily influenced by torque-convertor operation and slip, which the OEM handles quite well (we tested it down to S1 but in the end felt it was unnecessary to command it to go that low). All shifts 2,3,4,5,6 up and down are handled by the 'box'.
    FrankJake[QUOTED] and treimche like this.
  4. May 10, 2017 at 3:48 PM
    #284
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    You program an arduino board for this?
  5. May 10, 2017 at 3:56 PM
    #285
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    Some of the initial proof-of-concept was done with arduinos, but no, the final product does not use an arduino. The brain of the device is however a similar AVR microcontroller chip to that used on arduino.
  6. May 10, 2017 at 4:02 PM
    #286
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    OP, is there any way we can get confirmation which order numbers were included in the initial batch before you ran out of stock?
  7. May 10, 2017 at 4:46 PM
    #287
    IndyFastlane
    IndyFastlane Well-Known Member
    Looking forward to user reviews!
    I've gotten used to dealing with the stock shift pattern of the truck, but there are daily annoyances that it sounds like this may remedy. An example is when slowing to make a turn...after turning, you press the accelerator to increase speed and it immediately upshifts to 4th at the worst possible moment...so you have to press harder to make it downshift again. I know automatic transmissions can't read your mind, but this "smart" transmission is about the most counterintuitive I've ever driven. I feel like I'm constantly fighting to make the truck speed up.
    nDub, treimche and 0210 like this.
  8. May 10, 2017 at 5:59 PM
    #288
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Thanks to all of you who quoted my post! I personally was understanding this is how it worked but so many questions were being asked in a round about way that I don't think some of the members understood exactly how it was going to shift. I'm very clear on the matter now and hopefully we all understand it. Thanks again for the explanations. Tomorrow is the day.......
    0210 likes this.
  9. May 10, 2017 at 8:16 PM
    #289
    Austin09
    Austin09 Well-Known Member
    Austin tx
    2016 Barcelona Red TRD access can LB
    T-Rex grill with black bezel. Blacked out all the badges and added the Tacoma on the tail gate. The windows have been tinted to the darkest law will allow.
    I've had my taco for one year and reading this entire thread I decided to drive my truck like the way I think this box will work. I put the tranny in sport mode and didn't shift to a higher gear until the tachometer was around 2800 rpm and never shifted to 6th. So I was doing 75 and my cc worked great did not bounce around. And I didn't shift out of 4th under 50 mph. Not sure how much gas I went through but it felt like I had a lot of power. So if this thing does what I did myself with out me doing the shifting my in.
    tacogeorge likes this.
  10. May 10, 2017 at 9:47 PM
    #290
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    totally jelly.
  11. May 11, 2017 at 5:59 AM
    #291
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    Out for delivery from P.O.
    Already set the pop up menu settings for S mode to not take up the whole screen during shifts.
  12. May 11, 2017 at 6:01 AM
    #292
    Beerpayzdabillz
    Nor Cal
    2016 DCSB 4x4 sport
    The race is on! LOL
  13. May 11, 2017 at 6:22 AM
    #293
    TWTaco
    TWTaco Well-Known Member
    Dave
    [​IMG]OP would this 1ft cable be long enough to have the box located under dash? If not what do you recommend?
  14. May 11, 2017 at 7:05 AM
    #294
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
  15. May 11, 2017 at 7:20 AM
    #295
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    I may take a half day from work.
    over60, riz_atx, Tunngavik and 2 others like this.
  16. May 11, 2017 at 7:26 AM
    #296
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    You wont....:boink:
    zacinnc78 and goose443 like this.
  17. May 11, 2017 at 7:33 AM
    #297
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Do it. Tacomaworld needs your review... STAT
    over60 and riz_atx like this.
  18. May 11, 2017 at 7:40 AM
    #298
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2025 RAM 3500 6.7L Cummins
    Sorry if this was already covered, but with this device if you downshift on steep descents for engine braking does it still work?
  19. May 11, 2017 at 7:45 AM
    #299
    melikeymy beer
    Sorry, it was in the FAQS
    How do I cancel the control if I want to drive with the OEM manual sequential-shift mode?Simply make an S+ or S- shift by hand. At this point, the system cancels, provides an alarm, and reverts back to manual control. The device will stand-by and remain inactive until it is intentionally re-engaged by the operator (moving the lever into drive, and back to Sequential "S").
  20. May 11, 2017 at 7:49 AM
    #300
    melikeymy beer
    This appears to cleanly provide a 3rd drive operation mode. Very smart. Good job.
    JoeWillie likes this.
