ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 11, 2017 at 5:47 PM
    #361
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    You are already using someone else's points with the factory selection though aren't you? If it's better than that, it's a win in my book. I'll know tomorrow :)
    TWTaco likes this.
  2. May 11, 2017 at 5:52 PM
    #362
    erok81
    erok81 Well-Known Member
    Imposter
    I like how we've all tucked the unit into th floor mat.
    0210 likes this.
  3. May 11, 2017 at 5:54 PM
    #363
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Great minds think alike. Or y'all just pre-emptively copying me :D
    erok81[QUOTED] and RamP like this.
  4. May 11, 2017 at 5:54 PM
    #364
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    True, can't argue with that. But I could still use S on my own, or ECT. To be honest, the tranny hasn't been a deal breaker for me. I only really notice it at the 30-40mph bogged down and not moving times.
    riz_atx[QUOTED] likes this.
  5. May 11, 2017 at 5:55 PM
    #365
    0210
    Vancouver, BC
    One thing I forgot to mention is that the unit-cancellation features all work as described (unit self-cancels when you shift back into D, or shift the S-mode yourself). To be expected, but still.
    riz_atx and Pittrider[QUOTED] like this.
  6. May 11, 2017 at 5:57 PM
    #366
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    That's an awesome feature in the unit. I really give this guy credit, he thought of everything I didn't.
    vinkon235 and riz_atx like this.
  7. May 11, 2017 at 5:57 PM
    #367
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    You get the Canadian nod but I'm taking credit for doing it first in the states. :thumbsup::D
    JoeWillie, riz_atx and 0210[QUOTED] like this.
  8. May 11, 2017 at 5:58 PM
    #368
    erok81
    Imposter
    I have to say. Using s mode yourself vs this unit isn't the same. At all. I've spent plenty of time using the s mode and manually shifting. You still can't get away from the early downshifts. This gizmo greatly helps with that.
  9. May 11, 2017 at 5:58 PM
    #369
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Does the dash light up indicating you are in "S" and then show the gear number (1 through 6) when it shifts much like it does when you manually go into "S" and begin shifting yourself?
    Are they going to get rid of the "beep" and put the device in a smaller box? Must haves for me!
    riz_atx likes this.
  10. May 11, 2017 at 5:59 PM
    #370
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Haven't driven mine, but it's finally installed. Mine is 100% hidden under the center console. Plenty of room next to shifter to just lay it flat. I should've taken a pic before I closed it up.
    DeathsArrow, Cavedog, riz_atx and 4 others like this.
  11. May 11, 2017 at 5:59 PM
    #371
    0210
    Vancouver, BC
    It shows the S-mode the truck is currently in, which may, or may not coincide with the gear the truck is in.
    riz_atx likes this.
  12. May 11, 2017 at 5:59 PM
    #372
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Go drive it!!
    riz_atx and RamP like this.
  13. May 11, 2017 at 6:00 PM
    #373
    NINK
    NINK Well-Known Member
    Jake
    Rockdale, TX
    2016 Farmtruck
    Well maybe you could take it to someone with the right software, and have them adjust the shift points on this module.(if they aren't to your liking)?
    Wanna weigh in on this, @dcz108 ?
  14. May 11, 2017 at 6:01 PM
    #374
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    What's this beep business? Does it beep with each shift or just when you turn it on?
  15. May 11, 2017 at 6:02 PM
    #375
    JaTe
    Maryland
    Kids asleep...wife not home. Not leaving house any time soon. Family first for me.
  16. May 11, 2017 at 6:02 PM
    #376
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    You can change the settings so that the gear your in appears only in the lower left hand corner of the screen. And it does change with the shift points. Very nice, and the beeping is a non factor. It's very subtle. The truck beeps much louder.
    And the box is smaller than a dollar bill and will disappear under the console.
    DeathsArrow and riz_atx like this.
  17. May 11, 2017 at 6:04 PM
    #377
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    When you turn on the truck and when you shift into "S" but again it's very subtle. Won't beep with every shift. Also will beep if you disengage it by either shifting up or down in "S" mode or going back to "D". Totally not a big deal.
    JoeWillie and riz_atx like this.
  18. May 11, 2017 at 6:07 PM
    #378
    tacoflavoredkisses1
    Yea, that sounds 100% reasonable. The way people were bitching I thought it was every shift.
    JoeWillie, riz_atx and RamP[QUOTED] like this.
  19. May 11, 2017 at 6:09 PM
    #379
    Taco16LB
    Taco16LB Well-Known Member
    Someone who has it try ECT while in Shiftsense mode also to compare it.
  20. May 11, 2017 at 6:09 PM
    #380
    goose443
    Austin
    Texas
    Hah fair enough I was just kidding lol
    JaTe[QUOTED] likes this.
