ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 6, 2017 at 7:22 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Last thing I need to hear in my Tacoma is another beep, "audible alarm," every time I turn it on. You may want to re-think this.
    PvilleJohn, Boost3 and nat103 like this.
  2. May 6, 2017 at 7:23 PM
    toyguyic
    toyguyic Well-Known Member
    kdog
    Iowa City, IA
    2017 Tacoma Limited White
    TRD Pro Grill, Lo Pro QT, Morimoto HID
    TW is doing it again.....[​IMG]
  3. May 6, 2017 at 7:23 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    That's exactly what i was thinking
    PvilleJohn likes this.
  4. May 6, 2017 at 7:25 PM
    tcjacado
    tcjacado Well-Known Member
    Interested to see how it performs
    EL_INGE2017 likes this.
  5. May 6, 2017 at 7:25 PM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Nicely done fellow EE.
  6. May 6, 2017 at 7:26 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Sounds intriguing. It will be interesting to read the first few threads of folks using this product.
    Scott W and Krucen 01 like this.
  7. May 6, 2017 at 7:26 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  8. May 6, 2017 at 7:27 PM
    erok81
    erok81 Well-Known Member
    Imposter
    PvilleJohn and Lakeboy like this.
  9. May 6, 2017 at 7:28 PM
    erok81
    Imposter
    Ordered with phone. Can confirm PayPal doesn't work
    It said account was locked or something. And it's not my PayPal
  10. May 6, 2017 at 7:29 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    Clever idea. Love my 2017 generally, but definitely disappointed a little with it. My previous was a 2007 4cyl PreRunner SR5 (manual). I went with the V6 Auto because I wanted better acceleration than the previous.
    Question: Have you thought about enabling this through the ECT switch and leaving S so users can still shift manually? (Perhaps the Toyota code won't permit it?). Engage your device by hitting ECT, but pass the message to the computer that it is in 'S' Mode and run your code. Then if the user selects 'S', on the stick, disable your code and pass the original message to the computer. Would probably need a harness to connect it all up, but I don't see a reason that wouldn't work? You could probably retire with that one.....:oldglory:
    Jallred4 likes this.
  11. May 6, 2017 at 7:30 PM
    nat103
    KY
    2017 DCSB OR
    What he's doing is much better. Read the original thread
  12. May 6, 2017 at 7:34 PM
    WhiteBeltBatman
    WhiteBeltBatman Well-Known Member
    Bay Area, CA
    2017 Super White TRD Pro
  13. May 6, 2017 at 7:40 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    I'm guessing that's the only way to make this work without modifying original components and software. The S-mode allows user input via the shift lever, and this device probably acts as the "user."
    Yeah, +1 on this one. Not a fan of the audible idea. But I figure that if it gets too annoying, I'll open the device up and de-solder the speaker.
    nDub and toyguyic[QUOTED] like this.
  14. May 6, 2017 at 7:41 PM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    This sounds like pretty good news. I'll think I'll wait for a few of the members to report after they've installed this device. Does the plug under the shift console just plug into an empty plug or does it need to tap into one of the existing wires?
  15. May 6, 2017 at 7:42 PM
    #35
    RBaptist
    Newnan, Ga
    WhiteBeltBatman
    Ah - didn't see the S+/- override in this thread. Clever. I guess my thinking was to keep it a bit more 'stock' and let the S mode override his controller. So you'd have 3 shift modes: (1: Normal Crappy Mode, 2: ECT with his code, 3: When S is selected - it overrides Normal and His controller. So the 'Safety' feature would be either turning off ECT or selecting S mode. Same principle.... just a slightly different execution. Kudos to him for giving it a go with this. Personally I wish someone would open the code to the computer and develop an easy interface that would allow users to adjust shift points (within safety parameters)....probably a pipe dream though
    loginfailed likes this.
  16. May 6, 2017 at 7:42 PM
    #36
    0210
    Vancouver, BC
    I haven't seen the instructions, so I'm taking a guess, but I figure there will be three connectors on this thing. One will plug into the OBD2 port. The two other ones will allow the device to be connected inline with the OEM connector for the shift lever. So the original connection would be disconnected, and both resulting connectors would be plugged into this device.
    FrankJake[QUOTED] likes this.
  17. May 6, 2017 at 7:47 PM
    #37
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    I was hoping you'd go commercial with this. Any chance you could make the beeping user defeatable? Once the wife and kids are asleep I try very hard not to wake them up. ;)
  18. May 6, 2017 at 7:50 PM
    #38
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
  19. May 6, 2017 at 7:52 PM
    #39
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    I just posted a very low resolution version of the installation instructions. The higher-quality version will be uploaded overnight tonight and available tomorrow.
    https://youtu.be/KHVq7-3SlTA
  20. May 6, 2017 at 7:56 PM
    #40
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
