ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 12, 2017 at 7:01 AM
    #401
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    That was exactly what I was looking for! I use the Verizon Hum device and this will allow me to have both hooked up.
    chrisrocks300[QUOTED] likes this.
  2. May 12, 2017 at 7:06 AM
    #402
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    In order to comply with modern safety criteria and engineering-design practice, it is always a good idea to include a visual as well as audible indicator for operation of any device of this type. I think once you drive it you will find that it is not very intrusive at all, and should be hardly noticeable for the most part.
    vinkon235, RamP, JaTe and 2 others like this.
  3. May 12, 2017 at 7:06 AM
    #403
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
  4. May 12, 2017 at 7:30 AM
    #404
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    It's hardly noticeable. The seat belt chime is 10x as loud.
    JoeWillie likes this.
  5. May 12, 2017 at 7:40 AM
    #405
    jsey21
    I think you go to plaid...
    Nedrolls and RIDERED67[QUOTED] like this.
  6. May 12, 2017 at 7:41 AM
    #406
    speedy112790
    speedy112790 Well-Known Member
    Stephen
    2016 Tacoma SR5 4x4 DC TSS LB
  7. May 12, 2017 at 7:41 AM
    #407
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Mine is "Out for delivery" WOOT! :goingcrazy::goingcrazy::goingcrazy:
  8. May 12, 2017 at 7:43 AM
    #408
    speedy112790
    Stephen
    If you go to ect doesnt it disable the unit. When towing whats better to use. This or ect
  9. May 12, 2017 at 7:46 AM
    #409
    riz_atx
    Sohail
    Spicewood Texas
    It has not been mentioned that ECT use disables the ShiftSense. It has been stated that moving it to D or performing a manual shift in S would disable it.
  10. May 12, 2017 at 7:58 AM
    #410
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    We have tested it in ECT mode, and No, nothing bad happens. The ShiftSense still operates as intended with its programmed shift-maps. Since the OE shift maps are indexed up somewhat in ECT, you would notice a bit more overlap and the truck might make some more downshifts on its own, or hold out a bit longer on some upshifts than when the Shiftsense commands it, but only in the upper portion of the throttle range.
    Personal opinion here, but when I pull a trailer, I have resorted to using this instead of ECT because my truck still shifts up to 6 while in ECT, and I dont normally want that. I also like to have it holding 4th gear on grades a bit more than ECT does.
  11. May 12, 2017 at 11:37 AM
    #411
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    My only concern with this item is the lack of an on-board port to connect to a computer to update firmware. @dcz108 : You've stated in earlier pages that if there ever is a firmware upgrade (indicated likely doubtful), that customers would end up needing to mail the unit back to you. Realistically, that's really not sustainable for longevity of a product and overall good use of manpower. The Support vs. Sales/Manufacturing balance would become skewed to support.
    You may want to reconsider the possibility of a future firmware update happening, and possibly come out with a second version that empowers the customer more on maintaining the product for its life.
    That said, I will likely buy the product as-is. I need to wait some to re-pad my bank account after finally getting my truck yesterday. :D
    Cavedog, T8tjt and 0210 like this.
  12. May 12, 2017 at 1:00 PM
    #412
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Finally got a chance to drive it. Definitely works as advertised. I also have the Sprint booster installed. Gears definitely hold and doesn't shift too early. I'm playing with different modes on the Sprint booster to get it exactly the way I want it.
    I also tried it with the Sprint booster off definitely smooth and shifts when you expect it to.
    Need more time with it than the quick 30 minute drive I took.
    gulzeb, JoeWillie, Krucen 01 and 3 others like this.
  13. May 12, 2017 at 1:06 PM
    #413
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I like that the V3 sprint booster can also lock out the pedal . Nice anti theft mode . That's what convinced me to buy . Snappier throttle also must be nice .
  14. May 12, 2017 at 2:37 PM
    #414
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Pretty sure I read that when you tow you should keep it in 4
  15. May 12, 2017 at 5:24 PM
    #415
    TWTaco
    TWTaco Well-Known Member
    Dave
    shift.jpg Look what was waiting for me!! Will be installing very quickly and then off to do some testing , but its rush hour so no highway testing, later tonight for freeway.
    nDub, riz_atx, Idig63 and 1 other person like this.
  16. May 12, 2017 at 5:36 PM
    #416
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Can you please share with us exactly what the gauge cluster does when it goes through shifting, i.e.; does it go through the numbers along with "S" like it does if you manually shift the automatic? Still don't want to hear the beep..... Thanks!
    riz_atx likes this.
  17. May 12, 2017 at 5:38 PM
    #417
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    bump
  18. May 12, 2017 at 5:42 PM
    #418
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Same here but I'm in rear diff quarantine. Maybe the Corolla loaner will likey??:rofl:
    whiskeytacos and TWTaco[QUOTED] like this.
  19. May 12, 2017 at 6:01 PM
    #419
    riz_atx
    Sohail
    Spicewood Texas
    There is no beep on gear change. The screen will show the shift but can be disabled in the settings menu for the screen. Its pretty awesome so far. I got mine installed but havent had a chance to get it on any stretch of road. So far from 0-45MPH, 1-4th gear, the truck is in the power band, feels slightly more responsive due to being in the power band, but honestly, I am waiting to provide my full review. I would like to test my normal city driving and my normal highway driving. I will be all over this weekend and so will post my results in a day or 2.
    tcjacado and FrankJake like this.
  20. May 12, 2017 at 6:10 PM
    #420
    jsey21
    Ok... so has anyone used a Y splitter and had any issues w/ enough power to run two devices? Just wondering if that could be an issue if I try to run my Verizon Hum device along w/ this. I really want to use it, but wanted to check that first.
