ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 12, 2017 at 6:59 PM
    #421
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Why is this device necessary if TSB 0077-16 was supposed to fix the shifting? Many people have posted great results after getting the re-flash from the TSB.
    JoeWillie likes this.
  2. May 12, 2017 at 8:12 PM
    #422
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
  3. May 12, 2017 at 11:03 PM
    #423
    the629
    the629 Well-Known Member
    Northern 208
    2009 DCLB 4X4
    I don't even own a 3rd gen Tacoma (yet) and I'm looking forward to some solid reviews on the device.
    Kudos to DCZ for the R&D on this.
    JoeWillie, riz_atx and Idig63 like this.
  4. May 13, 2017 at 1:12 AM
    #424
    pocketsand
    pocketsand Well-Known Member
    SoCal
    2016 TRD OR Quicksand
  5. May 13, 2017 at 3:45 AM
    #425
    Persnickety
    Persnickety Well-Known Member
    2016 TRD Sport 4x4
  6. May 13, 2017 at 4:04 AM
    #426
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I waiting for someone to run a tank full of fuel through an post fuel mileage results using SS.
    Krucen 01 likes this.
  7. May 13, 2017 at 6:16 AM
    #427
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    I installed it Thursday night and used it for a drive to Houston yesterday. The install was easy and the unit performs exactly as advertised. The beeping is at a much lower volume than I expected and doesn't bother me at all.
    The shifting is improved in the 0-40 MPH range. I have a 35 MPH hill leaving my house and the truck will normally goof around with 4th and 5th gears. This unit does it perfectly (mostly 3rd and eventually 4th).
    I like the unit during acceleration up to highway speeds (keeps you in the powerband), but I'm a little less enthusiastic about low-throttle driving at higher speeds. I have a 45 MPH stretch of about 3 miles leaving my neighborhood that the truck normally handles very easily in 5th gear. This unit keeps it in 4th until about 57 MPH. If I could reflash it myself, I think I'd move the low throttle 4-5 shift down to 45 MPH. I'd also move the low throttle 5-6 shift down to 55 MPH. That is a personal preference though, as I don't mind needing a single-shift to get power when cruising.
    All the above being said, this unit does exactly as intended and exactly as advertised. The truck remains within the powerband instead of bogging down. I think this was a very clever idea and it solves the problem of early shifts during acceleration. I think I'll probably use it a lot during acceleration and then kick it over to D for cruising.
    Cavedog, riz_atx and IndyFastlane like this.
  8. May 13, 2017 at 6:23 AM
    #428
    Taco16LB
    Taco16LB Well-Known Member
    Nice review. Quick question for you . When you are cruising in D at lets say 65mph , when you put it over to S to engage the shift sense , what gear does it go into ? Edit, make that just under 65 as I see it will not go into SS if it is 65 or over.
    riz_atx likes this.
  9. May 13, 2017 at 6:40 AM
    #429
    Persnickety
    2016 TRD Sport 4x4
    Thank you!
    Idig63 and riz_atx like this.
  10. May 13, 2017 at 6:45 AM
    #430
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    @dcz108 Not to 'kinda' derail the thread - but I have to ask.
    What other vehicles are you working on developing this unit for?
    The 2015/2016 Colorado & Canyons have remarkebly similar shifting issues and are in need of something like this. Currently, the only options are tunes and the Pedal Commander just makes it feel 'unnoticable'. If you're not already on the www.coloradofans.com forum - you might get some interest in beta testers over there.
    I know the market might be much smaller due to the short existence of the 6 speed.....
    tacogeorge likes this.
  11. May 13, 2017 at 7:20 AM
    #431
    backtrack2015
    Austin TX
    It goes to S4 and then adjusts upwards as you would.
    Taco16LB[QUOTED] likes this.
  12. May 13, 2017 at 8:03 AM
    #432
    tacogeorge
    tacogeorge Well-Known Member
    George
    2016 Tacoma TRD Off Road
    Related but not related question...is there any way to customize how the cruise control works? I would love to limit my cruise to something like no more than +15% throttle position to maintain speed. I'm guessing that since cruise is ECU-controlled that it would basically have to be hacked in the same way that they are working on to do ECU tunes?
  13. May 13, 2017 at 8:09 AM
    #433
    tacogeorge
    George
    This made me smile a little at your expense...I was on the fence shopping between a Tacoma and Canyon. Not at all unhappy with my decision but every once in a while I wonder what kind of problems the GM guys are having. Its reassuring to know that the single biggest complaint that most people seem to have with their Tacoma is shared by you Canyoners.
    tcjacado, rnicholls, 0210 and 3 others like this.
  14. May 13, 2017 at 12:07 PM
    #434
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Exactly this, you don't need the truck being in 4th gear at 55mph unless you're using a decent amount of throttle to accelerate up to speed, <15% throttle it should change to 6th
  15. May 13, 2017 at 12:10 PM
    #435
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Here's a random idea... if you reset the transmission's "learning logic," and re-teach it exclusively using this device, would the tranny start shifting the way this device does?
    Or would the "learning" ignore any shifting that happens in S-mode?
  16. May 13, 2017 at 1:50 PM
    #436
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    A couple of thoughts related to this, and believe me, a ton of time was spent in establishing the minimum shift-points in the final mapping. As an example, for the 4-5 shift at around 57 mph: several months were spent tweaking in increments of 1/2 mile per hour from 45mph up through 62 while watching power, RPM, shift-counts, etc. What you will find is that the gear-ratio drop from 4-5 is pretty large. You could absolutely make the upshift into 5th at lower speed and low throttle, but it will leave you sitting well below the lower end of the power band. Any time you get back into the throttle for just a bit of grade or acceleration, it would require an immediate downshift right back to 4. One of the primary goals of the device was to significantly reduce the continual up/down/up/down of the OEM transmission, which means it is more desireable to keep the min-shift up just a bit higher to keep good separation between the upshift and downshift maps. The minimum-speeds in the map were all established to keep the engine RPM where it likes to be running, while at the same time mostly eliminating the constant up-down shifts of the OEM map. Because shifting any sooner would leave it immediately falling flat due to the large gear-ratio separations of this transmission. Hope this helps to explain it a bit.
    JoeWillie, Nickel, nDub and 6 others like this.
  17. May 13, 2017 at 2:06 PM
    #437
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    So basically what you've done with this novel device is "over-ride" the gas saving features that Toyota is mandated to achieve... Toyota has NO choice, I assume....they must meet a certain MPG requirement. If this "re-map" of the ECU brings the truck back to where the 2 gens were, then it's merely an "over-ride" to Toyota's Mandated MPG requirements...
    That's OK, but I think the MPG's are likely gonna drop as a result. I know that does NOT matter for a lot of people...me included.. But maybe it should be marketed as an "ECM override" ... device.
    Just a thought.... I don't mind the way my tranny works...now that I filled it..! 26.5 mpg CDN on the HWY.. (that would be like about 22 MPG US).. cuz you guys in the US have smaller gallons...!! hehe
  18. May 13, 2017 at 2:09 PM
    #438
    backtrack2015
    Austin TX
    You identified a problem, came up with a clever way to solve it, engineered/refined that solution, and brought it to market. My hat is off to you.... all I've ever done is whine about it. :thumbsup:
  19. May 13, 2017 at 2:23 PM
    #439
    over60
    Muskoka, Ontario
    Totally agree.... Wish the inventor lots of luck...!!
    I think this device will be a hit..!!
  20. May 13, 2017 at 2:51 PM
    #440
    Persnickety
    2016 TRD Sport 4x4
    dYL0n likes this.
