ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 14, 2017 at 2:31 PM
    #501
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    :facepalm:
    JoeWillie, Moonshine and arnette64 like this.
  2. May 14, 2017 at 2:32 PM
    #502
    speedy112790
    speedy112790 Well-Known Member
    Stephen
    2016 Tacoma SR5 4x4 DC TSS LB
    I bet this will help out lifted guys on bigger tires more than not lifted or bigger tires
  3. May 14, 2017 at 2:44 PM
    #503
    BeaverNation
    BeaverNation Well-Known Member
    It's funny that the auto trans was designed for and exists in the new turbodiesel hilux. Same ratios and everything. I bet it dominates in that platform with all that torque.
    treimche likes this.
  4. May 14, 2017 at 2:46 PM
    #504
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Took the plunge. Can't get any worse than it already is. Order 1107 placed. :fingerscrossed:
    JoeWillie likes this.
  5. May 14, 2017 at 2:54 PM
    #505
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    Care to elaborate?
  6. May 14, 2017 at 4:06 PM
    #506
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    He was just being unhelpful. Yes you can mount it anywhere you want, just make sure the power button is on.
    I received mine last Thursday but was out if town. Got home a few days early and got the unit installed today. Took maybe 12 minutes. I have mine laying on top of the qi charger since I don't use it. I'll probably just tuck it under the console eventually. I just wanted to get it installed and see how it worked.
    I only had time for a few miles but it does shift earlier without the need to push the pedal to the floor. I haven't had time for a nice long drive but so far it's $175 well spent. I think my order was #1034. Yes, for $175 I'd recommend it. It's a cheap fix if you are at all frustrated with the shifting. If you're ok with the way it shifts stock, then you probably don't need it.
    The beep.....anyone concerned about it don't be. Honestly I can't even hear it. I had to ask my passenger, "did you hear it beep". Their reply "yes but it's not very loud". If you had window down, sun roof open, music playing or A/C fan on more than medium, you probably won't even hear it.
  7. May 14, 2017 at 4:08 PM
    #507
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Thank you for the details. I'll be getting mine soon!!
    FrankJake[QUOTED] likes this.
  8. May 14, 2017 at 4:09 PM
    #508
    deanf
    deanf Well-Known Member
    Dean
    '16 Tacoma TRDOR & '15 4Runner Limited
    I am happy with my truck in D 95% of the time. I applaud your efforts to fix the alleged transmission issues. What I find most scandalous is the degree to which most owners are bereft of knowledge on the most basic functions of their truck. To wit: this thread.
  9. May 14, 2017 at 4:25 PM
    #509
    FrankJake
    Southern California
    Probably because Toyota doesn't point out the fact these transmissions shift much differently than people have become accustomed to them shifting. Most people have learned over the years that when you slightly press the accelerator pedal, the transmission shifts to the next lower gear. Not having to press it more than half way and then having it jump backwards two gears. It's great you're happy with the new, different shifting. Some of us are not. Choices are good.
  10. May 14, 2017 at 5:58 PM
    #510
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Received it Friday, installation took maybe 15 minutes - most spent trying to take off the center console - best not to 303 it the day before - it's a bit slippery if you do!
    I drove around 150 miles - a combination of suburbia, wide open freeway, and then center city traffic.
    Short review: The absolute BEST mod I've done to the truck!
    Long review: Installation was really easy - put it inside the center console using heavy duty velcro, fired her up and put her in S mode - heard the faint beep and tucked everything away. Easy!
    I've been doing this route a bit lately... The plan was to drive the entire way down as I have always done - in usual D mode with ETC engaged. The usual transmission issues that frustrate me and want me to get rid of her within a year or two... Such poor mapping on this vehicle...
    Did the return trip with the new software engaged - MUCH better - transmission shifted as I would have if a manual. Sure I thought the transition from 4-5 was a bit overdue, but realized that it was actually where it 'should' be given how 5th is quite the step... Same for 6th - I normally freeway cruise at around 70-75 and drive lazy to keep from having her drop back and forth between 5th & 6th...
    So I experimented - once on the open freeway, I just hit her back into D mode (without ETC) as I usually do for some 75 mph mellow cruising. Kept her there until I exited back into suburbia when I slid her back into S and the magic resumed.
    Mileage was about the same 21 mpg each way, so now noticeable change - but the frustration was gone while in the city & in suburbia , and I didn't have to engage ETC at all. Much better driving experience, overall. Well done!
    In terms of the beep - with the unit inside the center console, you actually have to listen for it and most people wouldn't even hear it if they didn't expect it. If you shift on the move, you wouldn't hear it at all..
    I'm glad I bought it and believe it's the reason I will actually keep this vehicle... I'm looking forward to tow with it as well.
  11. May 14, 2017 at 6:41 PM
    #511
    TWTaco
    TWTaco Well-Known Member
    Dave
    Are you driving all stock truck?
  12. May 14, 2017 at 6:51 PM
    #512
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Maybe I missed it, can this be tuned manually or is the standalone unit inside this tiny box locked away like Toyota does to its ecu's?
  13. May 14, 2017 at 6:55 PM
    #513
    Pawz2142
    Pawz2142 Active Member
    What do you normally get?
  14. May 14, 2017 at 6:59 PM
    #514
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    It's not tunable. I don't blame the creator either. He probably couldn't sell one that's highly tunable for liability reasons.
    Also, if it was open, then all the time and money he's poured into it could be easily copied and stolen.
    The only thing that I wish it had is a way to upgrade for future releases (if there are any).
    PapaBear[QUOTED] likes this.
  15. May 14, 2017 at 7:00 PM
    #515
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    Toyota did not need to tell me. I noticed it immediately when I drove the truck before buying it.
    Krucen 01 likes this.
  16. May 14, 2017 at 7:09 PM
    #516
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Has anyone used this for towing?
    My Tacoma doesn't like 65mph on the highway towing my camper, on any incline it downshifts to 3rd and stays there for quite some time even after getting back to flat ground. Sucks down gas too while towing.
    Would Toyota be able to detect this, thus denying any related warranty work?
  17. May 14, 2017 at 7:35 PM
    #517
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Like I said, I'm totally satisfied with the way my truck shifts. And with over 20k miles my average mpg is above 23 which is better than I was expecting. Good for the unhappy people to have an option.
    JoeWillie and over60 like this.
  18. May 14, 2017 at 7:52 PM
    #518
    indowaver
    indowaver Well-Known Member
    So, it's come down to trying this product or possibly trading. What sucks is this truck is like a super hot chic that's batshit crazy :)
    maxa, JoeWillie, over60 and 2 others like this.
  19. May 14, 2017 at 8:20 PM
    #519
    speedy112790
    Stephen
    Yeah you dont want to put a ring on it , you love to drive it but it could be even better?
  20. May 14, 2017 at 9:09 PM
    #520
    erok81
    erok81 Well-Known Member
    Imposter
    My cruise control is usable now!
