ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 15, 2017 at 9:55 AM
    #541
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Finally got to test it out for more than 5 miles. Red light never comes on, stays blue. I don't hear well so I don't hear any beeps but buddy said he hears 1 beep when moving shifter into S. It's shifting as described and showing the gear on the little screen by speedometer. But I thought the red light was supposed to be on when it's fully connected and working properly. Can I get some positive feedback please? Did I misread the instructions?
  2. May 15, 2017 at 10:03 AM
    #542
    Ibanez
    Ibanez Well-Known Member
    2016 Tacoma TRD 4 Door
    This is an interesting question that I have not seen a response to. OP???
  3. May 15, 2017 at 10:06 AM
    #543
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I wouldn't imagine it "learns" anything while in S mode.
  4. May 15, 2017 at 10:26 AM
    #544
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    After months of steady use, any time I switch back to D, I find it goes right back to its old habits. So no, i do not believe it learns anything while in S-mode.
    0210 and Ibanez[QUOTED] like this.
  5. May 15, 2017 at 10:37 AM
    #545
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    Aren't they all??
    Krucen 01 likes this.
  6. May 15, 2017 at 10:37 AM
    #546
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    The blue LED will remain lit any time the device is powered on. The red LED will light when the device is engaged. It comes on at the same time you hear the single beep.
    The red LED is kept a bit on the dim side (so as to not glow the dash or console at night), so I could understand how it might be tough to see, especially during daylight hours. I would recommend placing your hand over it once to see if it is actually lit.
  7. May 15, 2017 at 10:42 AM
    #547
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    My moms just got a new Highlander with the Tacoma 3.5, and 8-speed. She absolutely loved it, then I drove with her and complained how it constantly shifts, and is always in to high of a gear. Now she's all pissed at me cause she notices it now.
    It's still a really nice vehicle, but it is really high geared. I think reviews said it will do 80mph in 2nd.
  8. May 15, 2017 at 10:54 AM
    #548
    FrankJake
    Southern California
    Thanks I'll try it at night. It's working, I can definitely feel a huge difference which is so nice. Thanks for a great product.
    dcz108[QUOTED][OP] likes this.
  9. May 15, 2017 at 11:07 AM
    #549
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    :eek:
  10. May 15, 2017 at 11:16 AM
    #550
    hankk
    hankk Active Member
    hank
    Connecticut
    Was 2003 SR5 then 2014 SR5 now 2017 TRD Sport
    Question for the team. I did read thru all 29 pages and maybe missed it but will ask anyway.
    My '17 Sport has 2500 miles. I'm a key click away from ordering the device however, sooner rather than later she'll be going in for her first 5K Colonoscopy. Once the kit is installed and hidden away, if I simply pulled the OBD connector so the dealership would not give me big balls about the product, would I be able to use D and S mode as before and then simply plug the CPU connector back again after the checkup for it's functionality or would I still need to also disconnect the Shit controller cable also. Thank you guys.
  11. May 15, 2017 at 11:18 AM
    #551
    hankk
    hankk Active Member
    hank
    Connecticut
    Oh my, I meant "shift" controller. And I wasn't even using a smart phone.
    tcjacado, melikeymy beer and goose443 like this.
  12. May 15, 2017 at 11:18 AM
    #552
    Ibanez
    I believe it will respond like normal. No different than turning it off or putting in D mode.
  13. May 15, 2017 at 11:24 AM
    #553
    hankk
    hankk Active Member
    hank
    Connecticut
    Thank you Ibanez
  14. May 15, 2017 at 11:26 AM
    #554
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Yes, in the transmission document Toyota states AI ("learning") is disabled while in S mode. So for anyone who is ok with how their trucks shifts after an ECU reset but doesn't like the effect of the AI, driving is S6 will give the results you want.
  15. May 15, 2017 at 11:28 AM
    #555
    Ibanez
    I went ahead and placed an order today. I will remove every time I bring it to the dealer just to avoid any pointing of finders. I have the 8 year platinum so I'm not going to give them any reason to get out of it.
    0210 likes this.
  16. May 15, 2017 at 11:53 AM
    #556
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I just thought you were already mad at it
    melikeymy beer likes this.
  17. May 15, 2017 at 12:49 PM
    #557
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Instead of completely removing it when bringing it to the Stealership for service, I'll probably just unplug the OBD and tuck it under the dash - the techs at the Stealership are lazy and generally incompetent so I doubt they will ever notice it....
    over60 and RIDERED67 like this.
  18. May 15, 2017 at 12:57 PM
    #558
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Just make sure the device doesn't still beep when the truck is turned on. Theoretically, it should act as a "pass through" for the truck's original functionality, but if it does beep, that could draw attention to itself. Slim chance of anyone finding it, but depending on why the truck is at the dealer and potential future issues, it may be worth removing it altogether.
  19. May 15, 2017 at 1:13 PM
    #559
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I bit....Order #1116.
  20. May 15, 2017 at 1:20 PM
    #560
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    Yes, If the power switch on the device is turned off, it will act as a pure pass-through and will not engage or provide any beeps.
    0210[QUOTED] likes this.
