ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 16, 2017 at 4:56 PM
    #701
    Taco16LB
    Taco16LB Well-Known Member
    True , it sounded like you do almost all of your driving at 72 . I thought I read that all you have to do is put it in drive , then back to S to restart it at under 65 .
  2. May 16, 2017 at 4:59 PM
    #702
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    I did a 100mile round trip today at 72, cops everywhere so just not worth it. I know why he's made it hold 5th gear, so inclines and wind don't cause a downshift, however this is how automatics work, 6th gear is like 0.583 ratio to keep the RPM down, 5th gear slightly above for that reason, the downshift isn't so violent.
    Catch 22 really.
    Kilokato and Drakedischler1 like this.
  3. May 16, 2017 at 5:11 PM
    #703
    Taco16LB
    I hear you. I am waiting to see how this really works. Does yours lock up the torque convertor in 6th at 72 mph ? I have seen mine seem to lock /unlock or maybe it is going from 6th to 6th unlocked or is it 5th , then 5th locked ? I am not trying to be a smartass but it is hard for me to tell what the trans is really doing . I hope this makes sense .
  4. May 16, 2017 at 5:13 PM
    #704
    acemastr
    Aaron
    Tampa, FL
    OVTune
    I have no idea, I assumed it was always locked once you've got it spinning at a decent rate
  5. May 16, 2017 at 5:20 PM
    #705
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I usually tell by what the real-time mpg is reading.
    >15 mpg unlocked
    hovering between 15 and 30, half-lock
    25-30 locked
    This is in D.
  6. May 16, 2017 at 5:22 PM
    #706
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    DZ.....since mine has not been made yet, Order 1116, can you PLEASE disconnect the beep speaker in mine....PLEASE? I really am not looking forward to this regardless of how quiet it may or may not be. Last thing I want it so hear another noise. I am so anal that I will sit there and listen for it which will drive me nuts which will likely result in me removing it from my vehicle. I don't buy the "safety" argument as my auto trans shifter, gas pedal, brake pedal, and everything else potentially safety related doesn't beep when I use it. PLEASE disconnect it in my order????
    CenCal805 and Tacoma2GR like this.
  7. May 16, 2017 at 5:28 PM
    #707
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Had TSB rev 1 done and things were much better - decided to "order" and see how much it improves pulling my 1500 lb trailer exclusively in S mode. Order #1150, 2-3 wk delivery time. More to come.
  8. May 16, 2017 at 5:29 PM
    #708
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    It's a big improvement over the TSBs. You'll like it!
  9. May 16, 2017 at 5:31 PM
    #709
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    @dcz108 I'm on the same page... I'm order #1131 - anyway you can disconnect the speaker?
    Tacoma2GR likes this.
  10. May 16, 2017 at 5:34 PM
    #710
    Drakedischler1
    Drakedischler1 Well-Known Member
    Houston, TX
    2016 TACOMA TRD OFF ROAD QUICKSAND
    3" LIFT , 305 70 16 TIRES
    The beep is seriously not a big deal . It's so faint .
  11. May 16, 2017 at 5:38 PM
    #711
    Taco16LB
    You may not want to do this because it can be OCD , but watch the tach and see what it does at 72 . Like you said , a little wind or hill , and it changes . It is really hard to tell what is really going on . From what I think I know (lol), it is better for the trans temps to have the torque convertor to be locked up as there is no slipping. After the TSB rev-1 , was the first time I could ever get into 6th above 65 mph unless it was down hill or flat without wind . I have not used D since the TSB rev-1 for more than 20 miles , and I had it done 1200 miles ago. I have been using S5.
    Lakeboy likes this.
  12. May 16, 2017 at 5:41 PM
    #712
    Taco351
    Taco351 Well-Known Member
    Robert
    NLR/Sherwood
    2017 Tacoma Double Cab 4X4 TRD Off-Road White
    K&N air filter/LED lights/Magna Flow Muffler/TOYO AT2 Tires and lots of fun stuff.
    That's MY plan and why I decided to buy it. It's my hope the other shift points will make up for the inconvenience of shifting to 6th gear. The way I see it, it should be less shifting than what I have to do now.
  13. May 16, 2017 at 5:42 PM
    #713
    Taco16LB
    Half locked ? thanks , now you have me really confused lol. I too watch the real time mpg. but it is hard to tell what is going on .
  14. May 16, 2017 at 5:49 PM
    #714
    splitbolt
    NW Arkansas
    Toyota calls it flex lock; it's a solenoid operated TC clutch.
  15. May 16, 2017 at 5:56 PM
    #715
    Taco16LB
    No wonder why it is so hard to know what is happening . With the scan gauge it is an eye opener to watch the temps go up to over 210 even without towing in 60 degree weather. I am just trying to decide weather to add a larger cooler or not as I tow here when it is 100 degrees plus .
    This is another reason I feel this shift sense is a good idea , less slipping by being in too low of a gear.
    0210 likes this.
  16. May 16, 2017 at 6:03 PM
    #716
    splitbolt
    NW Arkansas
    Couldn't hurt. Seen some nice setups around here with their own fan.
    Those temps are why I'm changing fluid at 30K.
    0210 likes this.
  17. May 16, 2017 at 6:09 PM
    #717
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Last thing I would do would be add a cooler. The system is engineered. There is a reason they don't add a trans temp gauge. That shit can get well over 300* when pulling a hill. Could you imagine how many people would pull over and "let it cool down" that's why they run synthetic, you ain't gunna hurt it. Trans may have shifting issues, gaurenteed it will run longer than you will probably own the truck.
    monsterkx2fiddy likes this.
  18. May 16, 2017 at 6:12 PM
    #718
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    Can the mods delete pages 33-36 of the Rev limit nonsense?
    AverageJoe, NINK, CenCal805 and 13 others like this.
  19. May 16, 2017 at 6:18 PM
    #719
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
  20. May 16, 2017 at 6:27 PM
    #720
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I can barely hear it. Its a really low volume.
    On another note, I took my truck to the dealer today for warranty work and recall check and left it all connected and plugged in. They didnt mention it or say anything to me about it. Its very inconspicuous if you hide the module inside the console.
