ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. May 16, 2017 at 6:32 PM
    #721
    9TRDTCO
    9TRDTCO Well-Known Member
    Did you get a new 17 Sport now??
    Tacoma2GR[QUOTED] likes this.
  2. May 16, 2017 at 6:35 PM
    #722
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    maxa likes this.
  3. May 16, 2017 at 7:53 PM
    #723
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    It's obviously not a deal killer to me as I made the purchase... But if I can get it without why it's being built, which is what I prefer, than why not?
    Idig63 and riz_atx[QUOTED] like this.
  4. May 16, 2017 at 8:35 PM
    #724
    xeuxaz
    xeuxaz Member
    2017 White TRD OR
    Overall I'm really pleased with mine. My only complaint is that it doesn't use 6th gear on the highway. I have found myself using S mode with the shift sense for around town and normal D for the highway.
    BTW the beep is extremely quiet, especially when tucked away in the center console.
    Drakedischler1 and riz_atx like this.
  5. May 17, 2017 at 3:44 AM
    #725
    IndyFastlane
    IndyFastlane Well-Known Member
    I ordered mine about a week ago. In the meantime, I've been "manually" shifting just to mimics what the box apparently does. If it works as advertised, I think it'll be a winner.
    Been driving around a lot in s4 and s5 on city interstate and parkways to work over the last week.......interestingly, my mpg is at around 21mpg (200 miles of driving) which is the best yet for this truck. Previously I have always just dropped it in D and let it do its thing. I don't think that running a higher rpm is always detrimental to fuel economy......when you are in a shorter gear and light on the throttle, economy can be maximized. Along the same lines, being in a taller gear and bogging down can lower fuel economy. I'm optimistic about this little box.
  6. May 17, 2017 at 5:29 AM
    #726
    Drakedischler1
    Drakedischler1 Well-Known Member
    Houston, TX
    2016 TACOMA TRD OFF ROAD QUICKSAND
    3" LIFT , 305 70 16 TIRES
    After using it for a few days, I think I have a better experience manually shifting in S mode vs the ShiftSense. Its not shifting quite how I like , especially above 45 MPH.
  7. May 17, 2017 at 5:32 AM
    #727
    davidsp101
    davidsp101 Well-Known Member
    David
    Columbia, SC
    2017 TRD OR 4x4
    Can you elaborate? This has been my hesitation. Maybe it's just a weird quirk for me, but I don't mind it dropping to 5th and coming back to 4th when necessary (assuming I'm going above 45 mph).
  8. May 17, 2017 at 5:43 AM
    #728
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I have a question not related to the box but to S mode itself. If you use S mode, put it in
    4th does it run though all/hold all gears up to 4th the same way it does in D?
  9. May 17, 2017 at 5:51 AM
    #729
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Stock tires?
  10. May 17, 2017 at 6:07 AM
    #730
    Drakedischler1
    Houston, TX
    It seems to hold gear in 4th way longer than I like , keeping RPM around 2300 while cruising. I get it though, Its preventing the transmission from going into 5th , then down shifting when you accelerate . But , i would almost prefer this . This unit seems to totally take away from the bogged down stock shift points , but holds higher RPM / lower gear when city driving .. Its just a matter of preference . I'm not surprised, since this is what the unit is designed to do.. BUT , when im above 50 MPH , i'd rather be in 5th , getting ready for 6th, then holding the shift holding 4th gear , waiting for me to accelerate .
    Idig63 and Kilokato like this.
  11. May 17, 2017 at 6:08 AM
    #731
    Drakedischler1
    Houston, TX
    3" lift with 305s
  12. May 17, 2017 at 7:33 AM
    #732
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    Damn... and here I thought it was just me w/ one of those...
    DesertTaco4x4 likes this.
  13. May 17, 2017 at 9:09 AM
    #733
    tacosmine
    tacosmine Well-Known Member
    NW Oregon
    2016 SR5 White DCLB 4x4 Auto V6
    OEM style running boards
    Just installed mine Monday, yesterday a 60 mile round trip. Fighting a 30 mph headwind going one way, ran it with shift sense on in 5th gear. Shifts are much better and in the power range. I checked trip mileage when I reached my destination, 22.7 mpg. Tail wind coming back home, drove it in D. I live on a mountain, so it's always a 1000 foot climb out of town up mountain roads. The shift sense really shines on this type of road and makes the vehicle so much easier and more pleasant to drive. Best investment for 3rd gen owners! Took all of 10 minutes to install.
    riz_atx and jake slatnick like this.
  14. May 17, 2017 at 9:27 AM
    #734
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Just ordered one
    riz_atx likes this.
  15. May 17, 2017 at 1:02 PM
    #735
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    hoping to get mine by the end of the month. ill be going on a camp trip towing two jet skis about 3 hours away.
    wonder how itll run with my setup. i have 4.88 gears also.
    TWTaco and riz_atx like this.
  16. May 17, 2017 at 7:08 PM
    #736
    treimche
    treimche Well-Known Member
    Fargo, ND
    Been driving with this for a few days now too and have to say it is worth its weight in gold for around town driving. I'm very happy the upshift, bog, downshift garbage is gone when driving around town normally. For me, I kinda wish it held 1st gear just a bit longer, but I can just re-train myself to push the pedal a little harder. That is a bit difficult when turning from a stop but is a minor detail.
    The highway cruise control situation still isn't great, but I also haven't had much time on the highway yet. These motors lack torque, which makes the transmission constantly shift down looking for the RPMs where there is actually some power to be used. Also, once you drive over about 70mph, the lack of aerodynamics really drag on the the truck too, which amplifies the lack of torque. Seems like Toyota could simply reprogram 5th/6th gear tuning to accommodate.
    Props to the OP for all your hard work and ingenuity! When I read your original post, my instant thought was please produce and sell this thing. Boom here we are. You definitely made this truck much better to drive. Thank you!
    jake slatnick likes this.
  17. May 18, 2017 at 2:55 AM
    #737
    Marknett
    Marknett Member
    Mark
    Order # 1168
  18. May 18, 2017 at 4:12 AM
    #738
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    I drove a 650 mile trip yesterday with about 50 miles of interstate and the rest on 2 and 4 lane state highways. The SS*Pro worked great and kept the truck between 4th and 5th gear. It takes some getting used to - holding 4th longer than what I'm used to, but overall, it worked great.
    JaTe likes this.
  19. May 18, 2017 at 5:39 AM
    #739
    Drakedischler1
    Houston, TX
    Thats my only "snag" so far .. is it does hold 4th longer than desired .. i fined myself manually shifting to 5th once I want it.
  20. May 18, 2017 at 6:23 AM
    #740
    Raif
    Raif Member
    Why not just use shift sense about town and leave in D on highway
