ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Jul 17, 2017 at 10:36 AM
    #1561
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    lol, that part was awesome!
  2. Jul 18, 2017 at 12:13 PM
    #1562
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yeah...about that.
    Had my connector fall out of the shifter today...it's been +90°.
    It sucked driving around in D.
    bshammer0 likes this.
  3. Jul 18, 2017 at 12:36 PM
    #1563
    GotToyota
    GotToyota Well-Known Member
    Portland, OR
    Any update on when this could be available for the 4-cylinder trucks?
  4. Jul 18, 2017 at 1:35 PM
    #1564
    dinzzy
    dinzzy Member
    Greg
    2016 Tacoma TRD Sport
    Tow Package
    I saw the question asked but I did not see and answer...Can this device be used in conjunction with the Scan Gauge II...Y connector connected to the OBDII port?
    I tow a travel trailer and monitor my trans temps.
    Thanks, Greg
  5. Jul 18, 2017 at 1:49 PM
    #1565
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    I definitely do not miss the stomping I had to do before SSP. Can't remember the last time I stomped. Loving the SSP life.
  6. Jul 18, 2017 at 2:02 PM
    #1566
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    We recommend against using splitter with fast-polling devices because in some (rare) instances those devices can start to hog bandwidth over OBD, slowing the data that the SSP is looking for. However, if you are only monitoring temps with the scangage, those are typically slow data-refresh rates so I would not expect any issues at all.
    GotToyota likes this.
  7. Jul 18, 2017 at 2:06 PM
    #1567
    dinzzy
    dinzzy Member
    Greg
    Tow Package
    Thanks. I was hoping this device would alllow the trans to holdback 4th up grades while towing to keep my trans cool. When it continually down shifts it heat up very quick. Will it hold 4th longer while towing? Thanks
  8. Jul 18, 2017 at 2:40 PM
    #1568
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    You should be towing in S4 anyway, per the owners manual.
  9. Jul 18, 2017 at 2:42 PM
    #1569
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    Yes, that is one of the primary intentions of the device. Minimum upshift speed to 5th is 52mph. At speeds above that, it shifts up based on accelerator pedal position (demand). The SSP shift map is generally higher speed than OEM, so it will hold 4th longer before upshifting, especially in the low-mid throttle range. (see shift-map image on website)
    Since the SSP is basing its shifts on pedal, in that 52-65 mph range you can pretty much use the gas to command what gear you would like to be in. If you want it to hold 4th, keep steady moderate pedal pressure. If you want it to upshift to 5th, feather the gas slightly without letting off, and it will upshift.
    I agree with you on this btw when pulling trailer. It is much better when running steady in 4th, and keeps the tranny much cooler than the constant shifting up and down from 5th/6th. I had pulled an enclosed hunting trailer from PA to colorado when I first bought the truck (before SSP) and locked it in S4 for 3600 miles, running at 70-80 mph and it ran great!. The higher RPM took some getting used to, but looking at the performance curves, thats where this engine likes to operate! And gas mileage was better than my buddies F150 pulling equivalent weight.
    nDub likes this.
  10. Jul 18, 2017 at 3:29 PM
    #1570
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    How does this work with engine braking? Seems most of this is based on speed vs. engine load so where now my truck does a decent job of automatically shifting to 3rd on declines to minimize riding my brakes, would this hold true with the SSP?
  11. Jul 18, 2017 at 3:55 PM
    #1571
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    It does for me. A better job of it too imo
    bshammer0[QUOTED] likes this.
  12. Jul 18, 2017 at 3:59 PM
    #1572
    TejasTaco
    TejasTaco Grab a taco
    What is being done to make the black box fifty times smaller? That is the barrier to my purchase.
  13. Jul 18, 2017 at 4:03 PM
    #1573
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    You can easily hide it
    arnette64 likes this.
  14. Jul 18, 2017 at 4:08 PM
    #1574
    TejasTaco
    Is the pigtail to the shift lever long enough? I looked at the install video and it didn't look very long thus limiting placement.
  15. Jul 18, 2017 at 4:09 PM
    #1575
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    People usually hide it under qi charger and I think some even hide it behind dash.
  16. Jul 18, 2017 at 4:52 PM
    #1576
    jcfergus
    jcfergus Member
    Jim
    Roseville, CA
    2019 TRD Sport Access Cab
    TRD Pro wheels (gray), Snugtop shell
    I'm testing a mount location, vertically, cable connector down, just ahead of the console using a piece of foam mounting tape. There is smooth plastic there I suspect is ducting (I didn't crawl under the dash far enough to see what it actually is). The transmission pigtail is long enough, I can hear the beeps and if I need to power it off, its available by feel. It's practically invisible in this location. If it continues to work without a problem, I'll use the provided double-backed adhesive. I used smaller zip ties on the protruding screws at the lower edge of the dash to hold the excess OBDII cable.
  17. Jul 18, 2017 at 5:03 PM
    #1577
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    D engine breaking is better.
    But my brother nderstanding is SSP purposely doesn't do it quite the same. So when I know I'm coming to a grade I'll manually shift down or put it back into D.
    Minor issue considering how great the SSP is 99% of the other times.
  18. Jul 18, 2017 at 5:15 PM
    #1578
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Your answer is here:
    bshammer0[QUOTED] and nDub like this.
  19. Jul 22, 2017 at 7:16 AM
    #1579
    deadgame
    deadgame Well-Known Member
    2017 Tacoma TRD Pro
    I'm going to post this in the classified section later today, but I ended up going with the OV tune, so I have a Shift Sense Pro for sale. It's only been used for a week and works perfect. I'll let it go for $150 shipped if anybody's interested in saving themselves $25 off the price of ordering one.
    mrcamposd likes this.
  20. Jul 23, 2017 at 9:19 AM
    #1580
    deadgame
    2017 Tacoma TRD Pro
    Sold to DC!
