ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Jul 23, 2017 at 10:03 AM
    #1581
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
  2. Jul 24, 2017 at 7:30 PM
    #1582
    socal92
    socal92 Active Member
    2021 4Runner TRDOR
    Anyway to make the gear number not pop up on the HUD when it shifts? I'm fine with it being just down in the corner
  3. Jul 24, 2017 at 7:36 PM
    #1583
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    nDub, ShemRahBuck and socal92[QUOTED] like this.
  4. Jul 25, 2017 at 7:14 PM
    #1584
    Adk46er
    Adk46er Well-Known Member
    Upstate NY
    2021 DCLB MGM
    OEM bed mat Redarc Liberty brake controller Softopper US Truck Cap Rack Predator steps Tailgate inserts Bumpershellz Rear SumoSprings
    Has anyone done any serious towing using the ShiftSense Pro? I was wondering if it would help performance when towing a travel trailer.
  5. Jul 26, 2017 at 1:18 PM
    #1585
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    Just ordered a shift sense pro. Hopefully it arrives before my summer vacation so I can really test it out.
  6. Jul 26, 2017 at 4:06 PM
    #1586
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I would also be interested...
  7. Jul 26, 2017 at 11:36 PM
    #1587
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Another satisfied customer! Received my SSP very quickly and the install was super easy. I ended up tucking it under the Qi charger and I can still hear it beep when it engages and disengages. Drove a mix of city and highway and I am very pleased with the results. This is a must have for the third gen. I look forward to using this while towing my boat this weekend.
    BigSkyTRD, gshock and Hagendazsss like this.
  8. Jul 27, 2017 at 1:12 AM
    #1588
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Who can give input on how this works on steep grades or lives in the mountains?
  9. Jul 27, 2017 at 8:32 AM
    #1589
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    It definitely helps, but I still get a fair amount of back & forth shifting trying to stay in the 60 mph range while going over steep grades here in UT.
    TXTaco13[QUOTED] likes this.
  10. Jul 27, 2017 at 8:44 AM
    #1590
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I use SSpro almost all the time when I'm heading up the mountain. It'll hold the gear long enough to stay in the power band. Definitely shines in that environment.
    I have on occasion had the truck downshift before SSpro here in the Sierra Nevadas. But OP has said there is some overlap in the shift maps when the pedal is pushed down far enough.
    Also I tend to use D (or S manually) when going down grade b/c SSpro won't down shift early enough for engine braking, by design. Pretty minor though.
  11. Jul 27, 2017 at 8:47 AM
    #1591
    treimche
    treimche Well-Known Member
    Fargo, ND
    It is better than OEM, but there are times when the OEM shift points over ride the SSPro shift points and you'll get stuck in 4th gear, and sometimes all the way down to 3rd gear. The thing will sit and scream at 5500 RPMs thanks to the terrible OEM mapping and lack of low end power.
    TXTaco13[QUOTED] and rooster32 like this.
  12. Jul 27, 2017 at 8:48 AM
    #1592
    rooster32
    Utah
    I run into the "between" position in gearing....rpms way high to keep up speed or it bumps down a gear and not enough power to keep speed. I don't like driving my truck at +5k rpm's for 3-4 miles in order to keep my speed up (and this is with a basically empty truck).
  13. Jul 27, 2017 at 1:21 PM
    #1593
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    check post 1431 - maybe less in weight than some tow but certainly qualifies as steep mountainous grades.
  14. Jul 27, 2017 at 2:08 PM
    #1594
    rooster32
    Utah
    I have no clue what super fuel they sell in CO...but there is no way that I get anywhere near your stated mpg while towing or not. I put my 2 seater RZR on a lighter weight trailer and I'm lucky to get over 10 mpg up any incline. I'm all stock with 265/70/17" tires. I'll grab some video while driving up over Parleys Summit 7300 ft (not that high) here in Salt Lake City (main 3 lane hwy route to Park City Utah) next time I drag my RZR that way to show current mpg and shifting.
    At lower speeds, no problem, but get above 50-55 mph and its shift city trying to keep up speed.
    jgr81 and gulzeb like this.
  15. Jul 27, 2017 at 3:41 PM
    #1595
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I am hoping someone can help me confirm how my Shift Sense is operating. When I pull away from a complete stop at a stop sign, red light, etc., my Shift Sense is in 2nd gear. It never shifts into 1st gear even when pulling away from a complete stop. Is this normal? Why wouldn't 1st gear ever be used? Thanks all!
  16. Jul 27, 2017 at 3:44 PM
    #1596
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Operation manual:
    "the lowest command hear selection provided by shiftsense pro is S2. Even though the dash display may indicate S2 , the vehicle will still use 1st gear when starting out from stop. Sifts between 1 and 2 are heavily influenced by torque-convertor operation, which the OEM mapping handles well so it is left as-is."
    gulzeb likes this.
  17. Jul 27, 2017 at 3:45 PM
    #1597
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    S mode is a gear limiter. S2 means transmission shifts 1-2 as it sees fit. Dcz108 didn't want to mess with the 1-2 shift. Explanation for reason should be earlier in thread.
    Efit: i see someone already gave a better answer by quoting dcz108
  18. Jul 27, 2017 at 3:54 PM
    #1598
    rob4092xx
    Phoenix, AZ
    Okay....so just to be sure....the fact that mine starts out from a dead stop indicating 2nd gear is normal??? It never indicates it is in 1st gear....ever. Normal???
  19. Jul 27, 2017 at 3:55 PM
    #1599
    JKDer
    JKDer Well-Known Member
    SF Bay Area
    2017 TRD Off Road DCSB
    Yes, it's normal. :)
    FrankJake likes this.
  20. Jul 27, 2017 at 4:19 PM
    #1600
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    S2 just means gear is limited to 2 at most, but it is actually in 1st when you start from a dead stop.
    As an example, without SSP (or with SSP turned off), let's say you put it in S5. That means the gear can be anything from 1 to 5. Then move it to S4. That means gear can be anything from 1 to 4. SSP just does these S mode changes for you, all the way up and down between S2 and S6.
    ShemRahBuck likes this.
