ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Jul 28, 2017 at 12:41 PM
    #1601
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I'm no toyota tech but I would say something is definitely off with your engine/trans/ecu with that kind of towing mileage for what you pull. I use standard mid grade gas. Just got back from a 660 mile round trip (Golden to Durango and back) and averaged 24+ mpg. 4 in the cab and a bed full of stuff, but no trailer. The only things I have done that would remotely be considered engine mods are a GTek cai mod (can be found on this site) and the SSP. May want to remove and clean the MAF and reset the ecu. I'd be royally pissed with that mileage - enough to part with the Tacoma and go with a Tundra.
  2. Jul 28, 2017 at 1:50 PM
    #1602
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Wow. Down hill both ways? That's great mileage!
    I average about 19 mpg here in the foothills of the Sierras.
    I get 25+ mph on the way to work and about 17ish on the way home... a little over 1000' elevation change.
    rooster32 likes this.
  3. Jul 28, 2017 at 1:54 PM
    #1603
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    I average 17.5 in flat Texas. 19.6 was highest ever. However, let's stay on topic.
    JoeWillie and rooster32 like this.
  4. Jul 28, 2017 at 2:03 PM
    #1604
    slowboater
    slowboater Well-Known Member
    Mileage - up and down mountains (Going from Vancouver to Okanagon = real mountains) - If I want to keep it at 75mph or so on freeway, I'm LUCKY if I get 15 mpg. If I am cruising on flat ground at 50-60mph I push 20mpg (19.5ish).
    Shitty mileage.
    DCLB with a canopy.
    End thread jack.
    rooster32 and gulzeb like this.
  5. Jul 28, 2017 at 4:40 PM
    #1605
    GoldenBrew
    Golden, Colorado
    Agreed! Bought my SSP specifically for towing my camper. It works as expected and now I find myself using it when I want/need quicker response off the line.
    gulzeb[QUOTED] likes this.
  6. Jul 29, 2017 at 3:58 AM
    #1606
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    mine shifts into 4th at 35mph, normal ?,, only shifts at higher mph when heavier on the gas,, i unhooked it when i had it serviced and just plugged it back in,,, you dont have to go threw the setup again when its replugged back in ?
  7. Jul 29, 2017 at 12:36 PM
    #1607
    KruiserIV
    KruiserIV Well-Known Member
    Kanon
    2017 Tacoma TRD OR
    Apologies for my ignorance, but what's the difference between this and the OVTune? Do they do same/similar things?
  8. Jul 29, 2017 at 1:48 PM
    #1608
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    No, they are quite different types of devices with different intentions. The tune provides an alternate ECU programming which is intended to improve engine power and performance. The shiftsense is a plug-and-play device which is focused solely toward the transmission shift points (controlled through S-mode). It provides an alternate shift-mapping to allow the engine to use more of its RPM range, thereby getting up into the engine's inherent torque curve. It does not alter the stock ECU programming, it simply allows the engine to utilize the power that it already has.
    BigSkyTRD and nDub like this.
  9. Jul 29, 2017 at 1:59 PM
    #1609
    dcz108
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    Shifting to 4th gear at 35mph is normal for very low throttle position. That is the min upshift speed which is established for throttle positions <25 %. If you are heavier on the throttle, it will make the upshift at the appropriate speed (anywhere from 35-65 mph, depending).
    (by the way, if it is working correctly, you should also see it automatically indexing up and down through the gears in S-mode., which will be shown on the dash display)
    There is no setup required for the SSP, only a functional test (per operators manual). This test is recommended because it gives a very quick indication to the user that all electrical connections at the shift-lever are installed correctly and the unit is powered-on and functioning. It also confirms that the SSP is receiving data from the truck through OBD port. It is not necessarily required, although I would highly recommend it any time the 'shift-lever' connectors are removed or re-attached. I wouldn't recommend ever disconnecting any of those connectors for servicing because it is completely unnecessary. In some instances they may need to pull the OBD connector for servicing (if they are hooking it to tech-stream for any reason). If you like to disconnect the OBD before taking it in , that is fine. You do not need to perform the functional test again after plugging in OBD. If it is not connected, SSP wont engage, and it will give you 3-beeps. So you will find-out if it is connected or not right away when you attempt to engage it.
    nDub likes this.
  10. Jul 29, 2017 at 2:05 PM
    #1610
    mlevinson
    mlevinson Well-Known Member
    Raleigh, NC
    2017 TRD Off-Road
    Anyone near Raleigh NC have one of these? I'd love to ride in someone's truck who has it.
  11. Jul 30, 2017 at 9:24 AM
    #1611
    waydago
    waydago Well-Known Member
    Jack
    Jensen Beach, FL
    '16 Taco, TRD-OR, DCSB, SSM
    TRD Pro Exhaust, aFe Filter, Hard Tonneau, Predator steps, Pro Grille, Pro Fogs, Pro Badges, Pro Skid, Decal Inserts, H9 headlight swap, tailgate light bar, !7 in 4-Runner Pro wheels, 265/65-17 Falken Wildpeaks, AVS Bug shield and window shades, WeatherTechs, Sill protectors, pistol holster, Home Link mirror, Power tailgate lock, Redline Tuning hood struts, Caliper covers, Rigid Radiance light bar.
    Wow! I stumbled on this thread by accident and was quite intrigued. I have had my '16 TRD OR DC since the end of 2015. I have been annoyed, to put it mildly, by the erratic fumbling of the transmission looking for the right gear, whether in "D" or "S" mode, and whether or not ECT was engaged. Climbing hills (even little inclines like a bridge), cruise or no cruise, caused constant downshifting. The OP started this thread in May and it is already at 82 pages. I admit to not reading EVERY post but I got the gist early on. Most comments were positive and affirmed that this gadget really works.
    I have had my truck to numerous dealers, three locally in FL and the one in Hickory, NC (where I bought it), and had the TSB done (multiple times) and the fluid level checked. In all I asked for the TSB to be redone more than once as after the first flash it did not seem to help much at all except for the relief of the clunk from R to D. Revision 1 of this TSB superseded the original and I asked for that too. No help. I am told that once the ECU is flashed it cannot be undone so I don't know if Rev 1 is able to be flashed if the original was already done. I was told I have the "most current" flash for whatever that is worth. All dealers are not created equal in the areas of competence and knowledge or even customer service. They should operate as a Lexus dealer does in that regard.
    So taking this thread to heart I put out 175 George Washingtons to give it a try. I have spent more on less. My SSP arrived earlier this week after not much wait at all. So today, while the laundry was starting it's wash cycle, I hopped out to the driveway in the heat of the Florida morning sun and proceeded to begin the install. I watched the video last week and read the instructions this morning over coffee. From memory, the thing was a piece of cake from the start to the end of the functional test. The water had barely filled the washing machine. Well Ok, it did start agitating. It was a small load.
    I was so excited I had to drive it. Well my first Wow! is followed up by "holy crap Batman!" I only drove two miles or so and the first three quarters of a mile in my development has a 15 MPH speed limit so it really did not want to get out of 2nd gear due to the programmed shift points. Easy enough. Manually upshift to 3rd. The next test after the neighborhood had a 40 MPH limit so it wanted to stay in 4th. No big deal. Upshift to 5th. I do these things to keep RPMs below 2000 around town for economy sake, nothing else. Out on the open road I'll let her rip. Love the purr of the TRD Pro exhaust and the aFe intake filter.
    My take? A hearty thumbs up (so far at least). Gotta get on the interstate and check my local bridge. For now the around town driving should be much more pleasurable. Jury out on mileage after this. Currently I get 20-21 around town and better on the road. I have stock "size" wheels and tires and no gearing changes.
    I have spent quite a bit of dinero on my Taco making it my own with many Pro upgrades and I was on the verge of ditching it for a Tundra or even an ecoBoost F-150. Now I might have saved $15,000 for the time being and will keep my little TOY for a while longer. We'll see what changes for the Tacoma are in the works but as far as I can see there are none on the horizon in drivetrain improvements. Only Toyota's safety sense stuff is in store for the '18s.
    Bottom line. Hats off to the OP and the engineer(s) who did the grunt work to develop this beautiful tool. It might be a bit pricey but it beats $15,000 any day. Well worth the cost. I'm impressed. Kudos to OP dcz108 from one engineer to another. A couple minor suggestions OP. It might help to have longer cables, a smaller (if possible) housing, and to have the OBD cable coming out the opposite side of the connector. That's all I can critique. It WORKS!! Maybe you should talk to Toyota engineers who seem flummoxed trying to fix a well-known issue with the Gen 3 Tacomas.
    NOTE---Some separate info for those following this thread: Next on the horizon for Gen 3s is a safety recall to replace the Crankshaft Position Sensor (Safety Recall H1H). It is NHTSA recall No. 17V-356. The summary is the original sensor may have an excessive amount of anti-corrosion coating causing the sensor to malfunction. The MIL light might come on or the vehicle could run roughly, misfire or even stall. Stalling at higher speeds--don't have to say what could happen there. I already checked with one local dealer. They knew nothing of it (go figure) but after checking said they do not yet have the parts in stock. Hurry up and wait.
  12. Jul 30, 2017 at 9:29 AM
    #1612
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    When you up shifted it turned SSP off.
  13. Jul 30, 2017 at 10:00 AM
    #1613
    Boris20
    Boris20 Well-Known Member
    Jordan
    Oklahoma
    17 Tacoma TRD OR Quicksand
    Debating on getting one of these. I live in oklahoma and make long road trips often. The only thing about the truck that bothers me is the constant shifting when going down the interstate around 70-75mph. the slightest incline or winds make it drop to a lower gear, keeping the rps up around 3kish, then eventually back down to 2.2kish.
    Will this help keep it in 6th when cruising interstate?
    xenocide likes this.
  14. Jul 30, 2017 at 10:06 AM
    #1614
    splitbolt
    NW Arkansas
    75+ on flat interstate; yes.
    Otherwise, it stays in 5th.
    Not having 6th is no big deal as far as mileage goes. SSP downshifts less, so it's a wash.
    Whereabouts in Oklahoma?
  15. Jul 30, 2017 at 10:15 AM
    #1615
    Boris20
    Jordan
    Oklahoma
    Thanks for the input. Just wanting to constant gear shifting when going highway speeds to stop.
    Right in the Arm Pit of oklahoma.
  16. Jul 30, 2017 at 10:32 AM
    #1616
    splitbolt
    NW Arkansas
    Bethany?
    If you're ever close to NWA, I'll let you try mine.
    EDIT
    Or anyone else in or around NWA.
    melikeymy beer likes this.
  17. Jul 30, 2017 at 10:32 AM
    #1617
    waydago
    Jack
    Jensen Beach, FL
    I did not hear a beep to indicate that.
  18. Jul 30, 2017 at 10:34 AM
    #1618
    splitbolt
    NW Arkansas
    Something sounds amiss then.
    waydago[QUOTED] likes this.
  19. Jul 30, 2017 at 10:41 AM
    #1619
    waydago
    Jack
    Jensen Beach, FL
    I will double check on my next foray out after this Florida rain quits. Could be with the window down the breeze and road noise masked it.
  20. Jul 30, 2017 at 11:41 AM
    #1620
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    SSP can only keep the transmission in a lower gear than it would be otherwise, and that is its whole philosophy. It can not hold a higher gear. If you need power to maintain speed going up a hill, you will still downshift to 4th.
    Boris20[QUOTED] likes this.
