ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Aug 20, 2017 at 7:17 AM
    #1681
    Fino
    Fino Well-Known Member
    2017 Tacoma TRD 4x4 Double Cab
    Will give this a try first. 4:88's on the short list
  2. Aug 20, 2017 at 8:09 AM
    #1682
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Does anyone else experience a hard trasmission drop when down shifting in the lower gears? I'll be coasting to a stop and i will hear and feel like a hard knock as the transmission downshifts. Kinda afraid to keep driving it like that. Normal D no issues
  3. Aug 20, 2017 at 8:16 AM
    #1683
    treimche
    treimche Well-Known Member
    Fargo, ND
    Yep, its been discussed a little before too.
  4. Aug 20, 2017 at 8:25 AM
    #1684
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Do yourself a favor and get pedal Comander also .
  5. Aug 20, 2017 at 9:11 AM
    #1685
    Hagendazsss
    San Diego, CA
    Any fix for it? It only happens like 25% of the time when it starts to happen I just put it in drive
  6. Aug 20, 2017 at 9:37 AM
    #1686
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    It happens in all modes.
  7. Aug 20, 2017 at 12:47 PM
    #1687
    Boswell
    Boswell Active Member
    TRD off road
    I installed mine about a week ago an two things I have noticed,
    There is no beeping when I take it from S to D, Beeps on everything else.
    It HATES 6th gear, I can get it to shift into 6th but it will not stay. Doesn't matter if its at 78-85, once it shifts into 6th, if I try to maintain that speed it will ALWAYS down shift to 5th. Which sucks as 50% of my commute each day is at 75+ mph.
    Thanks,
    Boswell
  8. Aug 20, 2017 at 1:00 PM
    #1688
    TWTaco
    TWTaco Well-Known Member
    Dave
    Are you driving with a lot of hills, inclines,steep grades? Its meant to keep you in a higher rpm to maintain your speed. If you shift back into drive once you reach 75+ as you stated you will see that the constant up & down shifting that occurs in D. When the Pro is engaged you wont see a lot of 6th gear and its made that way! If for some reason you can hold 6th gear at 75+ on your commute then just leave it in drive! I highly doubt that it will and then just go back to SSP mode or whatever make you happy! I love the way it works for me! Good Luck :thumbsup:
  9. Aug 20, 2017 at 1:35 PM
    #1689
    Bootleg_Flyer
    Bootleg_Flyer Well-Known Member
    Virginia
    17 DCSB Off-Road
    Just put my SSP for sale in the classifieds. $120 pp'd and shipped CONUS.
  10. Aug 20, 2017 at 10:07 PM
    #1690
    Fino
    Thanks. I check it out.
  11. Aug 20, 2017 at 10:46 PM
    #1691
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Wow that bad huh?
  12. Aug 21, 2017 at 2:57 AM
    #1692
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    I had this issue as well. Started happening about a month after using SSP. Initially it only happened with the SSP, but it eventually started happening in D as well. I bought OVTune and no more hard down shifts. The shifting is now smooth with the SSP or in D. I've been debating if I should sell the SSP. The OVTune with SSP does feel like it accelerates even faster though. However, I rarely use the SSP anymore.
  13. Aug 21, 2017 at 6:16 AM
    #1693
    Bootleg_Flyer
    Virginia
    17 DCSB Off-Road
    I just wasn't using it. SSP does exactly what it claims to do, but my frustrations with the truck have more to do with the lack of throttle response and power maintenance than shift points. I feel like it would be a must have for folks in somewhat flat areas but here in the land where flat doesn't exist, it really didn't solve any of my issues: increase throttle ... nothing; increase throttle ... nothing; increase throttle ... nothing; mash throttle to floor ... downshift 2 gears rev to 5k rpm, blow past desired speed, upshift, decelerate to 10 mph below desired speed and start all over.
    scc, treimche and Blazingbluesport like this.
  14. Aug 21, 2017 at 6:44 AM
    #1694
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Sounds like you need a throttle booster.
  15. Aug 21, 2017 at 6:42 PM
    #1695
    Fino
    For those that have installed SSP, my main reason I had ordered this was for the initial throttle response from a standstill as well as better shift programing while driving. .....Majority of my driving is on flat ground as a daily driver.
    Will I notice much difference off the line or will I still need to stand on the pedal to get this truck to go?
  16. Aug 21, 2017 at 6:46 PM
    #1696
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Stand on the pedal and it will shift like it should have from the factory. :thumbsup:
  17. Aug 21, 2017 at 6:48 PM
    #1697
    Fino
    Sounds good! Should be arriving on Wednesday. .....Thanks
  18. Aug 21, 2017 at 7:02 PM
    #1698
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I don't have to slam pedal all the way now to get normal response off the line.
  19. Aug 21, 2017 at 7:07 PM
    #1699
    Fino
    Excellent! Thank you. I'm very happy to hear this. ....This truck has met all my needs, work and play. Looks like this may address my only complaint without the exspense of regearing.
  20. Aug 21, 2017 at 7:10 PM
    #1700
    gothamAlp
    gothamAlp Member
    2017 dcsb trd o/r
    some feedback/insights/thoughts on the SSP after about 3k miles worth of use.
    1. i orderd the SSP because the gear-hunting and over-shifting of the stock transmission was seriously impacting my enjoyment of driving my new taco
    2. with the SSP, my standard weekly 500 mile commute (250 miles each way, highway miles, mostly using cruise control) is MUCH more enjoyable
    3. i drop the shifter into S and let the SSP do the work, and while the cruise control will still 'override' the SSP to maintain speeds,
    4. gear-hunting is essentially eliminated (the truck stays in 5th or 4th longer than in the OEM setting -- and the almost constant back and forth between the two overdrive gears is a thing of the past)
    5. and over-shifting is dramatically reduced (i did half of my commute today, 250 miles with over 5,000 feet in elevation changes, mostly using my cruise control, and i would guess that the transmission shifted at least 50% less often than in OEM setting)
    6. additionally, my mileage on that commute has improved, by a few MPG's as a result, i think, of items #4 and #5 (i.e. fewer of the 'corrective' down-shifts the stock transmission setting overuses)
    as others have noted, with SSP, the truck shifts the way "you think it should" -- it gives you more high end of the gears and the truck feels more engaged as a result. i vastly prefer driving with it, even at lower speeds around town, and on the highway the difference is in fact, as i hope i've explained above, dramatic.
    lastly, i want to give a shout out to the OP for some excellent customer service. i re-located the unit after my initial installation and didn't realize that in doing so i'd damaged a connection that affected the SSP's functionality; while i ended up repairing the unit myself, the OP's guidance and offering of various solutions was very gracious and helpful, and i really appreciated the support.
    overall, i'd conclude by saying that this is the single best mod i've made to a truck that i was very excited to own and drive, and that i now in fact greatly enjoy owning and driving.
    cheers.
    FrankJake, DanIsMe, 'comatose and 5 others like this.
