ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Aug 21, 2017 at 7:31 PM
    #1701
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    agreed x1000
    dcz108[OP] likes this.
  2. Aug 21, 2017 at 7:45 PM
    #1702
    Fino
    Fino Well-Known Member
    2017 Tacoma TRD 4x4 Double Cab
    A couple more question. (and I thank you all in advance for your responses)
    I've read "Yes" ECT in SSP mode and I've read "No" ECT in SSP mode.
    What's the correct answere?
  3. Aug 21, 2017 at 7:46 PM
    #1703
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    ECT works just fine with SSP. I never liked ECT without SSP, so I never use it with SSP either.
  4. Aug 21, 2017 at 7:48 PM
    #1704
    Fino
    .....Also, what are the best mounting positions?
    Has anyone left it mounted inside the shift console? Will I need to access the on/off switch on the unit for any reason, perhaps to tow in S4 with ECT on?
  5. Aug 21, 2017 at 7:51 PM
    #1705
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    To put in regular S mode, all you have to do is move into S and then move it up or down to disengage SSP. To turn SSP back on, move it to D and back to S.
    I have mine hidden in console (pushed under qi charger slot), and have never felt the need to access it.
  6. Aug 21, 2017 at 8:04 PM
    #1706
    Fino
    That's where I've decided to mount mine too. My only apprehension is, and correct me if I'm wrong, but it looks like the SSP unit has an on/off switch. I believe I read in a previous post it will tow better in S4 with ECT than the SSP unit. ...Again, this is in regards to towing.
    Thoughts?
  7. Aug 21, 2017 at 8:22 PM
    #1707
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    To put in regular S4 without using the power switch:
    1. Move from D to S (puts transmission in SSP mode)
    2. Shift up or down (this will turn SSP off, and put it in regular S mode)
    3. Shift to S4 (now it is in regular S4)
  8. Aug 21, 2017 at 8:35 PM
    #1708
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Just wait for the super charger. The demand is high, but they just need time to engineer it.
  9. Aug 21, 2017 at 8:41 PM
    #1709
    Fino
    Love it! Thank you for your reply. So no need to manually turn it off to run it in factory S4 with ECT. Just shift it in S mode will shut it off and put it in S4 for factory shifts if I feel it tows better like that.
    Thank you again for your response.
  10. Aug 21, 2017 at 8:47 PM
    #1710
    Fino
    Do you have any pics of it mounted in console? Is there much space under the qi charger and is the access to that space under the transmission cover?
  11. Aug 21, 2017 at 8:49 PM
    #1711
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Sorry, did not take any
  12. Aug 22, 2017 at 1:36 AM
    #1712
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    pull the plastic flap out where the wire is routed, and tuck it up behind there towards the forward of the flap,, it will stay in there on its own,,, with switch facing down,, you wont be able to see it..
  13. Aug 22, 2017 at 1:43 AM
    #1713
    Fino
    Thanks bludweiaer.
    I saw that location. I'm still waiting for it but took the liberty opening up my console. I see a lot of space under the qi charger slot. I think Im going try it there first.
  14. Aug 22, 2017 at 7:28 AM
    #1714
    gothamAlp
    gothamAlp Member
    2017 dcsb trd o/r
    hey, fino!
    now that all of your questions have been answered...
    how 'bout a little more cowbell?
    :D
  15. Aug 22, 2017 at 8:36 AM
    #1715
    Fino
  16. Aug 22, 2017 at 10:11 PM
    #1716
    Fino
    Ended up installing unit under qi charger slot. Taped switch to "I" ON just in case so it won't bump to "0" OFF position while it is tucked hidden in the console. Only needed 1 zip tie. Unit is totally hidden. Installation was super easy.
    Limited drive time but initial impressions are good. Will give full opinion in a week or two after I have more time behind the wheel with various driving conditions.
    Thanks again to everyone for the helpful insight and opinions on the unit and installation.
    r1200gs4ok, gulzeb and smitty99 like this.
  17. Aug 23, 2017 at 5:31 AM
    #1717
    scc
    scc Member
    Essentially this is the number one issue I cannot get past. Not even the shifting so much as the constant rpm swing. On a gradual highway climb it seems physically impossible to adjust the throttle via pedal to maintain speed; it's either 2500rpm or 3500-4000rpm & then an almost instantaneous rpm drop back down to appease the mpg gods.
  18. Aug 23, 2017 at 7:23 AM
    #1718
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    That big jump is down to how much difference there is in gear ratio between 4th and 5th. Can't really do anything about how big the jump is, but SSP will make such jumps less frequent by holding 4th longer.
  19. Aug 23, 2017 at 8:32 AM
    #1719
    scc
    scc Member
    I owned used & enjoyed the SSP... great product, does what it says
    I'm not referring to gear changes. This past w/e was in S4 on long 2-3 mile climb on highway. While running 2-2500 rpm & need more you cannot [in my truck] throttle up to say 3500-3800, it will peg right to 4-4500 throw me over preferred speed & immediately drop back to 2k
    Over & over & over....
  20. Aug 23, 2017 at 9:22 AM
    #1720
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Must be a slow highway. Going 70+ mph puts 4th gear around or above 3k rpm.
    I'm not sure why rpm would take big jumps if no gear change.
