ShiftSense Pro - transmission shift controller for Gen3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, May 6, 2017.
  1. Oct 5, 2017 at 8:08 AM
    #1861
    itsraymondang
    itsraymondang Spam King
    Houston, TX
    2017 White TRD Sport DCSB
    With this plugged in, I have to be on the "S" mode?
    Or can I leave it on "D"
    PvilleJohn likes this.
  2. Oct 5, 2017 at 8:25 AM
    #1862
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    You can put it in D for normal factory Shift points as the SSP controller is not active in D mode....Or you can put it in S for the SSP Shift controller to take over and control on their Shift points. You can also still change manually in s mode and it will cancel the SSP and allow you to control
  3. Oct 5, 2017 at 10:30 AM
    #1863
    Neil K
    Neil K Member
    Kamloops BC
    2017 Inferno TRD
    Makes the truck livable!
    I found the constant gear hunting and engine lugging Very annoying, and this little device has all but solved the issue. I came from a manual GTI, so the auto trans is a new feeling anyway, but Toyota really did a poor job in the drive-ability department with this trans!
    Install was very easy and I hid it under the console. Instructions are clear and easy to follow, including the use of the V2 selections.
    #1 seems as though it will be excellent for highway cruising
    #2 for all around driving
    #3 for towing.
    A big thanks to DZ Custom Innovations, I'm not sure if I would have kept the truck without you!
    Beerpayzdabillz and 44mger like this.
  4. Oct 5, 2017 at 10:33 AM
    #1864
    itsraymondang
    Houston, TX
    In other words, it only works in “S” mode
    PvilleJohn[QUOTED] likes this.
  5. Oct 5, 2017 at 11:49 AM
    #1865
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Is the #2 setting the same as the V1 chip?
  6. Oct 5, 2017 at 11:59 AM
    #1866
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    I think it's supposed to be. I ordered the new chip because it's only $12. I'm curious to see what number 1 does at lower speeds around town. I love my v1 now for long trips and mountain passes. Curiosity got me to upgrade to v2.
  7. Oct 5, 2017 at 11:59 AM
    #1867
    jeffsmitty
    jeffsmitty Active Member
    Jeff
    Northport, Alabama
    TRD Offroad 4x4
    2017 White TRD pro grill
    Pvillejohn. Remembered how to get anoying shift display changed. On steering wheel scroll to settings. Click on pop up display. Scroll down to shift position and uncheck it. That'll get you.
    nDub likes this.
  8. Oct 5, 2017 at 12:38 PM
    #1868
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Do you have the latest one with the 3 different modes you can switch between?
    You are like me and running 285's which totally screw up everything with the SSP. You need to put it in the lowest of the three modes, as that will essentially be like the "normal" mode if you were running stock sized tires. Kinda funky how it works with running the bigger tires, but with the updated version it solves that problem.
  9. Oct 5, 2017 at 12:41 PM
    #1869
    PvilleJohn
    Powdersville SC
    SVT Raptor
    You got it
  10. Oct 5, 2017 at 12:43 PM
    #1870
    PvilleJohn
    Powdersville SC
    SVT Raptor
    I honestly don't have a clue what version I have. I just ordered whatever was on the web site a few weeks ago. I assumed it was the latest and greatest....interesting.
  11. Oct 5, 2017 at 12:46 PM
    #1871
    Bootleg_Flyer
    Bootleg_Flyer Well-Known Member
    Virginia
    17 DCSB Off-Road
    From what I can tell ... not entirely. It seems to be a little more refined and sensitive to throttle input. For example, with V1 my truck would absolutely not shift out of third gear until 38 - 39 mph. With V2 it shifts in between 34 and 40 mph depending on throttle position.
  12. Oct 5, 2017 at 2:35 PM
    #1872
    PNWTacoma
    Paul
    Thank you for your input. I think I'll now get based on that. It will be interesting how this will drive when I get my gearing done too. Hopefully I won't need the SSP anymore.
  13. Oct 5, 2017 at 4:45 PM
    #1873
    whoodie
    whoodie Active Member
    Jon
    2017 Tacoma DCSB TRDOR 4x4 Quicksand
    Just filled up after having the SSP in the truck for the week. Love it when Fuelly says "Best tank so far!". Commute is 50-50 freeway and bumper to bumper traffic. Usually average mid 17's. Now I'm seeing low 19's. It's great when mods will pay for themselves. @dcz108 , again, great job and thank you!
    JoeWillie, Beerpayzdabillz and nDub like this.
  14. Oct 7, 2017 at 4:49 PM
    #1874
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Just got done test driving the V2 chip, Level 3.
    @dcz108
    This is my 2nd upgrade chip...
    Is Level 3 more on par with the first, original SSP program?
  15. Oct 7, 2017 at 4:58 PM
    #1875
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    splitbolt[QUOTED] likes this.
  16. Oct 7, 2017 at 5:27 PM
    #1876
    splitbolt
    NW Arkansas
    nDub[QUOTED] likes this.
  17. Oct 7, 2017 at 5:38 PM
    #1877
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Level 2 ~ V1.2
  18. Oct 7, 2017 at 5:40 PM
    #1878
    splitbolt
    NW Arkansas
    Okay...is Level 3=V1.1?
  19. Oct 7, 2017 at 8:52 PM
    #1879
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    No
  20. Oct 8, 2017 at 12:05 PM
    #1880
    itsraymondang
    Houston, TX
    The only thing holding me back is that the instrument gauge cluster shows the gear position every time it shifts... Is there any way for it not to pop up every time?
