ShiftSense Pro vs Pedal Commander?
Discussion in 'Performance and Tuning' started by SSCHUU, Aug 29, 2017.
  1. Aug 29, 2017 at 3:42 PM
    SSCHUU
    SSCHUU [OP] Well-Known Member
    Eric
    Southern California
    2017 Tacoma 4x4
    Debating between the two. Which one should I go with?
    I mainly use the truck as a daily driver but want some added drivability on the day to day as the truck just doesn't seem to have enough go at the low end especially
  2. Sep 1, 2017 at 6:20 AM
    SSCHUU
    Eric
    Southern California
    2017 Tacoma 4x4
    Anyone have experience with both that might be able to shed some light on the differences?
  3. Sep 1, 2017 at 7:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
