Shim packs for the carrier bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dyna962007, Nov 19, 2017.
  1. Nov 19, 2017 at 10:48 AM
    dyna962007
    dyna962007 [OP] Well-Known Member
    Edwardsville IL near Saint Louis MO
    Tacoma 2016 TRD OffRoad / Previously 2007 4wd
    3" lift kit. 17" wheels and tires, custom grill, full technology package, Early model running boards, Push bar.
    New information, when I apply the brakes, there is a vibration that continues until it comes to a complete stop BUT, if I put the truck into neutral and brake, smooth as silk. what does this tell us?
    I have a 3" lift on my truck, pretty inexpensive kit with leaf spring blacks in the back, etc etc.
    All the proper shimming was done to the front differential etc.
    But the drive shaft angle is obviously off a bit to the rear differential.
    I complained to the dealer that there was a slight vibration only when braking and coming to a stop. The dealers answer is its the lift kit and drive line angel and I am "feeling the u-joints".
    I have fixed this type of thing myself over the years with my jeeps and such by measuring the angle and getting it close by shimming the bearing down and getting it plenty close.
    The 4-WD shop that did the work told me the angle was not bad enough to worry about when I first had it installed and there is NO vibration on the highway.
    SO I was planning on just doing the same thing and shimming it down a bit.
    I tired it yesterday and installed about 1/4" of shims to shim it down.
    I rant it and found that to have NO affect on the vibration.
    But my real question is this, using washers to shim it down is a little bit half ass.
    Someone told me they make shim kits for this that are more like a small block, larger and matches up with the bracket size and is a better more substantial fit.
    Anyone heard of this?
  2. Nov 19, 2017 at 10:52 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Tell us what you have for a lift, take out the diff drop up front as it does nothing for our 2nd and 3rd Gen Tacoma's. So lets start with the actual lift first, what is it?
  3. Nov 19, 2017 at 10:58 AM
    highmountainpanda
    highmountainpanda Active Member
    2017 TRD Pro, MT
    Hope you get it figured out. My 07' had a horrid vibration when braking. Tried everything I possible could to get it to stop and never did find a proper solution.
  4. Nov 19, 2017 at 11:10 AM
    dyna962007
  5. Nov 19, 2017 at 11:12 AM
    dyna962007
    On a side note, always trying to learn here but, the shop told and the ebay seller agreed the differential drop was needed to correct front drive line issues, your saying no. Please tell me more. This is a subject I would like to know more about. I though I had the front end of this thing whipped.
  6. Nov 19, 2017 at 11:12 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You spent all that money on a beautiful truck and sorry put that garbage on it?
  7. Nov 19, 2017 at 11:14 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    @T4RFTMFW James you are better at this stuff can you explain to him why our 2nd and 3rd Gen Tacoma's don't need the diff drop.
    T4RFTMFW likes this.
  8. Nov 19, 2017 at 11:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Fuck if I know. I had a Prerunner. :p
    Unchained 5150 likes this.
  9. Nov 19, 2017 at 11:21 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thank You sir
  10. Nov 19, 2017 at 11:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    @nd4spdbh you must know about this stuff
  11. Nov 19, 2017 at 11:45 AM
    dyna962007
    so we are going to leave it there? You make a statement that the differential drop is not needed in contrast with what the parts kit seller AND the 4wd shop that installed it said but have no explanation as to why?
    Dude I'm happy to give you the benefit of the doubt and as I explained I want to learn more, but you cant just leave it like that?
  12. Nov 19, 2017 at 11:47 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  13. Nov 19, 2017 at 11:55 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Did you put shims/spacers under the center carrier? That's the easiest and cheapest place to start, then at the leaf spring-axle if you have to.
    But, if it only happens while braking, wouldn't bad brake rotors be the leading cause?
  14. Nov 19, 2017 at 12:30 PM
    dyna962007
    Its not a brake rotor type feeling, not a warp warp warp feel as it comes to a stop. Usually they feel kind of in and out but this is a constant vibration only when getting close to stopping and hauling it down
  15. Nov 19, 2017 at 12:31 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Does it happen in 4 Wheel Drive as it could be the Needle Bearing issue they get after lifting.
  16. Nov 19, 2017 at 1:09 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The weak ass springs are loading up causing the pinion to dive down; ruins the pinion angle resulting in vibration. Blocks, especially tall ones, are notorious for amplifying this effect.
    Try putting some spring clamps around the forward part of the leafs, to reinforce the mainspring, and see if you notice any difference.
    You can try addressing angles; but what good does that do, if the angles change under loading or unloading of the springs.
    Surprised you don't mention a clunk or thud while stopping...
    GF8er likes this.
  17. Nov 19, 2017 at 1:53 PM
    splitbolt
    NW Arkansas
    Carrier bearing adjusment shouldn't really be needed unless it's off from the factory. This basically tries to mimic a one-piece with two standard u-joints by zeroing the center working angle. Thing is you'll never get it down far enough without serious binding in the carrier bearing.
    On a 2-piece with 3 standard u-joints, the transfer case/forward u-joint working angle is zeroed, while the center and pinion working angles should be equal to cancel each other.
    Don't know what kind of driveshaft you are used to on Jeeps...
    If it had a double-cardan/CV; that's different set up too...
  18. Dec 23, 2017 at 5:12 PM
    dyna962007
    So your saying that when you appply the breaks, the differential noses down? and this is the opposite of the diff going up when accelerating?? I'm confused but either way, I would buy into your weak spring issues for sure. Does anyone know where you can get spring clamps made just for our spring sizes??
  19. Dec 23, 2017 at 5:19 PM
    dyna962007
    guys, new info.
    The vibration I Have been having when braking, goes away completely if I put the truck into Neutral when coming to a stop and braking??
  20. Dec 23, 2017 at 6:01 PM
    splitbolt
    NW Arkansas
    When and how often does it occur?
