Shim rear axle while lift install or wait?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tsmitty2661, Nov 20, 2018.
  1. Nov 20, 2018 at 1:12 PM
    tsmitty2661
    tsmitty2661 [OP] Member
    Tyler
    2018 Cement TRD Sport LB
    Hey guys,
    After reading I cant seem to decide whether to install a 3 degree axle shim when I put the lift on or not. Im installing 5100s with 888 coils and an icon AAL with the overload in so itll be about 2" in the rear. I have a DCLB and don't see much people commenting about vibrations with the long bed....(already did the ECGS bushing)
    Any help from DCLB guys would be awesome
  2. Nov 20, 2018 at 1:50 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Hey man. Heres my experience
    DCLB
    At the time of install of my HD dakars I switched out the center pins with longer ones and an extra collar. This allowed me to easily loosen the ubolts later down the road if I experience vibes, and slide the slotted shims right in. Got the center pin and collar from headstrong and it was a cheap yet wise decision because I did indeed get vibes, and going this route saved alot of work. Since then, no vibes, no issues.
    Hope this helps
    Good luck
  3. Nov 20, 2018 at 1:55 PM
    sorgon82
    Ont. Canada
  4. Nov 20, 2018 at 2:01 PM
    tsmitty2661
    Tyler
    Damn wish I would have came across this earlier. I have half a mind to just throw my 3 degrees in when I do it....i don’t think it could hurt anything?
  5. Nov 20, 2018 at 2:05 PM
    sorgon82
    Ont. Canada
    No you probably need it anyways. Between those and that ecgs bushing it should drive smooth
  6. Nov 22, 2018 at 8:52 AM
    tsmitty2661
    Tyler
    Got it all installed last night and rode it around. Everything seems good so far! The shims I ordered ended up being that kit, I thought it was only the shims! I did end up putting them in. Thanks man!
