Shim revalving and order
Discussion in 'Suspension' started by crhsharks12, Oct 24, 2019.
  1. Oct 24, 2019 at 6:38 PM
    crhsharks12
    crhsharks12 [OP] Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    I have some shocks I will be rebuilding and I am thinking of Revalving them also. I am familiar with the rebuild process of shocks, and I understand how they work, but I want to know what shim sizes I should get (or if I should keep the stock ones) and if I should change their order in the tube. Obviously valving is application based and is personal opinion all in all, but I would like some advice on this if you don't mind.
    I have a 2006 DCSB TRD, with an aftermarket rear bumper, softopper, and bed mat (~ 220 Lbs in the rear unloaded), so I do not have too much weight in the back (maybe another$150 for camping gear). I have 650 Lb coils in the front with nothing on my front. My suspension setup is a pair of Icon 2.5 coilovers in the front, (so I guess this will apply to my Icon 2.5's upfront also) and the 2.0s in the rear.
    Most of my miles (~90%) are highway, on road, or dirt roads. I am a weekend warrior when I get the chance and do go to the mountains a lot in the winter and spring. When I do go off road it is generally a fire road or some OHV trail in the mountains, so really its more of slow stuff, but I enjoy going faster over terrain if I can since its so exhilarating. Also, Cali roads are sometimes more rough than most OHV trails LOL. For mainly road driving, trails, and fire roads which I hit at 35 or so, what should I do about shim size and the shim stack? Should I keep it stock? I like the Icons digressive valving because I really can feel it smooth out the faster I go or the heavier I load, but Tacomas are light trucks, and also, on-road driving at anything less than 50 can be a bit stiff. get thinner shims? place a smaller shim set first, go to medium sized ones, back to small, and then the large? Or, should I just not care and leave it the way it is.
  2. Oct 25, 2019 at 2:30 PM
    crhsharks12
    Denver, CO
  3. Feb 20, 2020 at 2:09 AM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    You ever figure this out?
