Shimmy front end after 3in lift answer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 70guitarman, Sep 26, 2021.
  1. Sep 26, 2021 at 7:15 AM
    70guitarman
    70guitarman [OP] Member
    Eltee
    Tucson
    2005 Tacoma sr5 trd double cab
    3inch lift duel flowmaster set up
    Installed 3inch lift on my 2005 taco started shimmying on freeway any one had this happen?
  2. Sep 26, 2021 at 9:30 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you get an alignment done?
  3. Sep 26, 2021 at 9:55 AM
    70guitarman
    Eltee
    Tucson
    Yes the Alignment was included but the only shimmer is on freeway at about 65 or so new brakes and caliper.
  4. Sep 26, 2021 at 10:03 AM
    tcjacado
    tcjacado Well-Known Member
    Are the lug nuts torqued properly on the wheels? 85 ft lbs
    wilcam47 likes this.
  5. Sep 26, 2021 at 10:14 AM
    70guitarman
    Eltee
    Tucson
    Thanks I'll check that.
  6. Sep 26, 2021 at 10:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does it only happen when you hit the brakes? Or all the time at 65?
  7. Sep 26, 2021 at 10:32 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    What type of 3" lift ? May need to correct the driveline angles with a carrier bearing drop along with rear shims. Are the alignment values within specs if you are running factory UCAs?
    tcjacado likes this.
  8. Sep 26, 2021 at 11:01 AM
    MadMule
    MadMule Active Member
    Emory
    Aurora, CO
    Tacoma TRD
    Toytec/Bilstein-3 "li ft kit with 5160 rear shocks, spidertrax spacers
    • Check your rims for missing weights?
    • Check the brake pads for uneven wear, if a caliper is hanging up that could be a cause?
    • Does the lift kit require a spacing at the center bearing?
  9. Sep 26, 2021 at 12:44 PM
    70guitarman
    Eltee
    Tucson
    Yes I checked not Shure about bering I'll check oversized tires and rims.
  10. Sep 26, 2021 at 12:48 PM
    tcjacado
    When was the last time upper and lower ball joint serviced/replaced and or tie rods... inner and outer?
  11. Sep 26, 2021 at 12:57 PM
    70guitarman
    Eltee
    Tucson
    Just turned 89000 Toyota dealership doesn't know.
  12. Sep 26, 2021 at 1:18 PM
    MadMule
    Emory
    Aurora, CO
    Tacoma TRD
    wheel bearings could also cause the vibration
  13. Sep 26, 2021 at 1:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  14. Sep 26, 2021 at 1:26 PM
    70guitarman
    Eltee
    Tucson
    Yes at 80 it stops could it be the tires?
  15. Sep 26, 2021 at 1:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The rotors are warped. Replace them and check for sticky caliper pistons
  16. Sep 27, 2021 at 9:15 AM
    MadMule
    Emory
    Aurora, CO
    Tacoma TRD
    I agree if its only when you hit the brakes, that's why I suggested checking the pads for uneven wear. You may not need to replace the rotors if they are thick enough to turn, but it sounds like a brake job is in your future. It's less likely the tires if it's only really when you hit the brakes, unless it's defective and then you would see a bulge in the sidewall or tread, that's rare. You could always get your tires rebalanced, you probably received a free lifetime balancing when they were installed. Tires should be rebalanced every couple of years anyways and that would eliminate them from the list of possibilities.
  17. Sep 28, 2021 at 11:03 AM
    FuzzyWuzzy
    FuzzyWuzzy Member
    Vancouver, WA
    07 TRD Sport
    My 3" lift came with sway bar relocate brackets, front differential drop, and rear axel shims. Drives perfect. If you haven't installed these its most likely the culprit.
  18. Oct 4, 2021 at 9:23 AM
    70guitarman
    Eltee
    Tucson
    Thanks for all response to the 3inch lift problem it was simple fix sway bar brackets drives ok now.
    jeminyned likes this.
