Shims and lubrication for front brake pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Apr 1, 2017.
  1. Apr 1, 2017 at 3:25 PM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    The pads for my truck that I am ordering are 04465-AZ001-TM and come with shims. What is their purpose and how do I use them? Are they for adjustment of the pads if the rotors are turned down or something different? How do I use the shims? Thanks
    paul
  2. Apr 1, 2017 at 5:17 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    shims go on the back of the pad
    and touch the piston and prevent squealing brakes
    it's sound suppression that's all it's for
    Lucifer1 and RacecarGuy like this.
  3. Apr 9, 2017 at 8:35 AM
    Paulrv6
    paul
    2005 Tacoma
    In the pad kit I got some moly lube. Where does this get applied? Is it on either side of the shim and against the piston? Do I also need brake grease for the pins and sliding surfaces on the pads or is that what the moly lube is for? Just want to use the proper lubes on the contact points. Please advise. Thank you
    paul
  4. Apr 9, 2017 at 9:32 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    the molly lube is for the sliding points and pins. don't use grease on the back of the pad.get some disc brake quiet to put on the back of the pad. it helps with brake pad rattle.
    Lucifer1 likes this.
  5. Oct 28, 2018 at 12:53 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Did you reuse sliding bolts and cotter pins?
  6. Oct 28, 2018 at 1:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can re-use the sliders as long as they are clean and not pitted or rusty. The cotter pins can be reused if they are still springy and not bent/mushed out of shape
    Slvr14tacoma and Lucifer1 like this.
  7. Oct 28, 2018 at 1:16 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    All the above is good and helpful advice, you should have no trouble.
    Slvr14tacoma likes this.
  8. Oct 28, 2018 at 5:36 PM
    Slvr14tacoma
    Mid travel
    Yea looks pretty straight forward just ordered some oem pads with shims. Rotors look good only 60k on them. Just need to rent a caliper piston separator thing from autozone and should be good
