Shims for EL095R Dakar leaf springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phoenixpiole, Jan 17, 2019.
  1. Jan 17, 2019 at 2:27 PM
    lloverso
    lloverso Active Member
    Pa
    2018 Tacoma TRD Off Road
    ProComp 3/1 Nitro Level Kit Diff Drop Spacer 17x9 Method 312 -12 Offset 285/70/17 Nitto Terra Grappler G2
    The vibes aren’t that bad honestly just annoying. I only feel it when decelerating at 25mph and highway speed of 65mph. I already tried the cb drop and it did nothing. A 1” block shouldn’t throw it out that bad which leaves me to believe the angles were already screwed before the lift. The truck only has 5k miles on it so it’s frustrating for sure
  2. Jan 17, 2019 at 2:41 PM
    phoenixpiole
    phoenixpiole [OP] Well-Known Member
    2018 Tacoma DCSB SR5
    I agree it is frustrating my truck is at 6k with this issue, acts like it’s 20 years old lol.
    Here is a link to a guy that went above and beyond to solve driveline vibrations and he did evetually after a lot of trial and error: https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
    lloverso[QUOTED] likes this.
  3. Nov 15, 2020 at 9:46 PM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    If I installed an extended bolt initially to put the shims in, and now I want to take the shims out, would I need to go back to the stock length bolt, or the new longer one will still work without the shim?
  4. Nov 16, 2020 at 5:33 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    That might depend on the length of the bolt afterwards, the bumpstops you are using and whether of not it will interfere with the bumpstops. You can always put the extended one back in and trim it down if it is too long.
  5. Nov 16, 2020 at 5:36 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Cut to desired length. Leave a 1/4 inch of exposed thread above the nut.
