SHIMS...Help
Discussion in 'Suspension' started by TSubatis, Sep 10, 2009.
  1. Sep 10, 2009 at 4:16 AM
    TSubatis
    TSubatis [OP] Well-Known Member
    Boston, MA
    2007 DC 4x4
    Billstein 5100s + Toytec TSB AAL, 17" Moto Metal Blacks, 275/85 Toyo Open Country A/T's, BHLM, Satoshi Grill, Sport Hood, Kenwood DNX5120, Kicker Speakers
    Hey guys,
    I'm installing my AAL with TSB in the rear of the truck, and going ahead with installing 3* Toytec shims to prevent any vibes.
    Might be a stupid question, but which way to the shims go in? Thick end towards the front of the truck? My buddy and I installed them this way and it looks funny, we're second guessing ourselves.
    Please help!
  2. Sep 10, 2009 at 4:36 AM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    ya you second guessed correctly. thick ends to the back of the truck. you want the plum to point up.
    Did you get the toytec shims? If so thats what I have and it came with instructions.
  3. Sep 10, 2009 at 9:48 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Doesn't the thick end go towards the front of the truck?
  4. Sep 10, 2009 at 10:05 AM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
  5. Sep 10, 2009 at 10:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No. Thin side tward the front.
  6. Sep 10, 2009 at 10:09 AM
    Canadianboy
    James
    Vancouver, BC
    I may also have to install some shims to get rid of a small vibration, good to know. Thin side toward the front.
  7. Sep 10, 2009 at 11:46 AM
    beginah
    beginah Well-Known Member
    the ones from toytec has a cavity cut out, i'm assuming that faces up. Is that correct?
  8. Sep 10, 2009 at 11:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes
  9. Sep 10, 2009 at 1:26 PM
    trailmaster308
    Louisiana
    ya like Chris said. That cavity is so you can get i past the leaf spring bolt...at least that what it seams like when i installed mine.
  10. Sep 10, 2009 at 1:28 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    What does TSB mean?:confused:
  11. Sep 10, 2009 at 2:03 PM
    trailmaster308
    Louisiana
    Technical Service Bulletins
  12. Sep 14, 2009 at 9:16 AM
    TSubatis
    Boston, MA
    2007 DC 4x4
    unfortunately my shims did not come with instructions, but tacomaworld saved the day.
    thanks guys, was a quick fix...just loosened up the U-bolts and flipped them. Also put in the driveshaft drop. Slight vibes from 5-10mph and 15-20mph, but barely noticeable. definetly not bad enough for a tom woods driveshaft (well maybe eventually)
