Shims or carrier drop or both?
Discussion in 'Suspension' started by Marcoc, Mar 31, 2014.
  1. Mar 31, 2014 at 6:51 AM
    Marcoc
    Marcoc [OP] Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Getting ready in a few weeks to install my OME full kit w/Dakars and LR UCA's. Currently I have a coil spacer up front for 2.5" and AAL in the rear for 2". I have 3 degree shims installed and I have a light vibe between 10-20mph. Its not bad at all and it drives fine at any other speed. I would like to eliminate the vibes with the OME kit. I will be using the measuring how to's on here to adjust it but my question is I have the CustomTacos carrier bearing drop thats designed for 2-4" of lift that will be getting installed at the same time should I also do 3 or 4 degree shims as well? I would need to order the ones that slide under leafs before i start anything. Any thoughts?
  2. Mar 31, 2014 at 9:06 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you plan on using the slide in style axle shims with Dakars I hope you know you will need centre pin collars
  3. Mar 31, 2014 at 1:11 PM
    Marcoc
    Connecticut
    Oz yes I actually ordered new collars. The center pins on the dakars should be long enough I hope. Pretty much I am thinking do the carrier drop and see how it drives. Then decide on shims that slide in if I need them.
  4. Mar 31, 2014 at 6:22 PM
    OZ-T
    Peter North
    British Columbia
  5. Apr 2, 2014 at 6:11 PM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    Are the shims bad? Could you install them when installing the leaf pack? Don't you have to replace u-bolts if you torque them then take them off to put in shims?
  6. Apr 2, 2014 at 8:17 PM
    Marcoc
    Connecticut
    I have reused U-bolts before. I have loosened them to make adjustments and retorqued them. I retorque if needed every oil change while I grease DS. I hopefully wont need shims after the carrier drop but once I install the lift its the only way to tell
    I would'nt reuse the u bolts more than twice personally.
