Shims. Where to buy?
Discussion in 'Suspension' started by Bearskill, Sep 6, 2009.
  1. Sep 6, 2009 at 6:20 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Looking for some 1* to 3* steel rear axle shims. Just did a little search online. the couple places I checked don't have them for the 05+ Tacomas. For those of you that have shimmed you axle, where did you get them from?
  2. Sep 6, 2009 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you checked Wheelers, and Toytec?
  3. Sep 6, 2009 at 8:00 PM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    got mine from toytech after i put their AAL and adj coilover's on. Realized I needed a little extra angle on the rear axle to get rid of the shakes.
  4. Sep 6, 2009 at 9:26 PM
    Bearskill
    Sac
    The ones on Toytec's site are Zinc.....? Why is that? Why not Steel?
