Shims with Progressive AALs
Discussion in 'Suspension' started by FergBoi93, Feb 25, 2024.
  1. Feb 25, 2024 at 5:04 PM
    FergBoi93
    FergBoi93 [OP] Active Member
    Cragan
    North Carolina
    2025 Toyota Tacoma TRD Off-road iForceMax
    Do I need to install shims when I install a progressive 3 leaf AAL pack to gain 1.5 inch rear lift? Also, is there a rule of thumb for what degree shims to get for 1.5 inch rear lift? Thanks
  2. Feb 25, 2024 at 5:08 PM
    Bishop84
    Bishop84 Well-Known Member
    No, and the rule of thumb is shim when needed. So go ahead and do it, if there's vibes, then its time to check angles and consider shim.
    I installed the Icon 3 leaf recently on my sisters tacoma and it was perfect.
    FergBoi93[OP] likes this.
  3. Feb 25, 2024 at 5:11 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rule of thumb for rear lift is 1 degree of angle for each inch of lift.
  4. Feb 25, 2024 at 5:20 PM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    Ah yes, down the rabbit hole you go! Unfortunately there is no good rule of thumb, in my experience.
    Shims, carrier bearing drop, complicated drive line angle measurements are all things some people have to do IF they have drive line vibrations after lifting their truck.
    Some folks have no problems at all. I had to do all kinds of BS with the same Icon leafs Bishop84 had no issues with.
    It is not entirely voodoo, there is a very systematic way to deal with vibrations, but it is very much specific to each individual vehicles. It does suck having to take apart a bunch of stuff you just did if you find you have vibrations. I ended up needing a 2 degree rear shim, non-standard carrier bearing drop, and needle bearing replacement up front when it was all said and done for less than a 2 inch lift.
  5. Feb 25, 2024 at 5:30 PM
    FergBoi93
    Cragan
    North Carolina
    Ah ok. Thank you for the response.
  6. Feb 25, 2024 at 5:30 PM
    FergBoi93
    Cragan
    North Carolina
    Awesome. Thank you
  7. Feb 25, 2024 at 5:31 PM
    FergBoi93
    Cragan
    North Carolina
    Oh ok. I gotcha. Well, hopefully I end up being a lucky one and not have to do any extra stuff when I install the AALs but we will see.
    dirt_seeker[QUOTED] likes this.
