shims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outlawtacoma, Nov 13, 2009.
  1. Nov 13, 2009 at 2:59 PM
    outlawtacoma
    outlawtacoma [OP] Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    Will I need axle shims if I install 5100's? I have a leveling kit now, and am going to be taking it off to install the 5100's. I currently have a small driveline vib at 35mph. Just wondering? Thanks fellas
  2. Nov 13, 2009 at 3:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can install them and see if it helps the vibe. If not, they are easilly removed.
  3. Nov 13, 2009 at 3:04 PM
    outlawtacoma
    W. TN
    I have em sitting in the garage, just havent had the time to do it.
  4. Nov 13, 2009 at 3:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you changing anything in the rear suspension?
    The front suspension (5100's) won't have anything to do with the driveline vibration......
    So, if you currently have a vibe and you're not changing anything in the rear - then I would recommend installing the shims and see if that helps.
    What size shims are they? 2.5* is the smallest you can get and probably all you'll need.
  5. Nov 13, 2009 at 7:05 PM
    outlawtacoma
    W. TN
    Yeah I have the 2.5* degree shims from toytech.
  6. Dec 2, 2009 at 9:51 PM
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    Did you ever install the shims? i'm curious because i just added a leaf to my rear with the 5100s and i think i have a 5-10mph vibration; not sure if i'm being paranoid. if you did install them, did that solve your problem?
  7. Dec 3, 2009 at 4:17 AM
    Janster
    Jandy
    Lancaster, PA
    As Chris mentioned above....buy some 2.5 degree shims (they're cheap), install them and see if it helps. The install should be fairly easy if you do some research and get some people to help you with it.
    If you install the shims properly without any other issues - you really can't go wrong and it won't hurt anything.
