Shit day
Discussion in '1st Gen. Tacomas (1995-2004)' started by Canuckcrawler, Feb 17, 2017.
  1. Feb 18, 2017 at 7:11 AM
    chaosrob
    chaosrob Well-Known Member
    Oh man, sorry to hear that. I appreciate you posting this as a warning to others though
  2. Feb 18, 2017 at 7:54 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    That sucks OP. Anyway to contact original owner to find out what brand and date? I'd be looking to try and go after manufacture of ball joint if mileage and time is low enough.
    HEED THE WARNING PEOPLE...........OEM BALL JOINTS!!
  3. Feb 18, 2017 at 8:00 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Definitely interested if you get any info on brand/mileage/date of install from the previous owner, OP. I'm not one to crucify certain brands immediately. As a former tech I know that the actual hands installing the parts can have a bigger impact than the manufacturer.
  4. Feb 18, 2017 at 1:06 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I hear ya, but not on this part. This part is truly to be replaced with OEM only. Do just a little research here in first gen forum for posts by @Dirty Pool about the Lbj's. He's dissected a few of the different makes. Proof is in the pudding.
  5. Feb 18, 2017 at 3:18 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    This is the reason I picked up my 96 for as cheap as I did. The only real damage that came from it was obviously the upper and lower ball joints, tie rod...the hub wasn't included in purchase so who knows where that ended up. Also the fender needed replaced and still have a nice dent in the lower rocker. Good luck and remember it probably looks more expensive than it really is.
  6. Feb 19, 2017 at 7:32 AM
    1997tacomav6
    Denver
    Sucks, but the bright side is it happened when you were going slow with minimal damage,
    Could have happened when you were going 60mph and flipped the truck.
    Rule of thumb as most of us know here, always use OEM balljoints and you won't have this problem and change The balljoint every time you change timing belt 100,000. I have 520,000 miles, never had a balljoint issue,
  7. Feb 19, 2017 at 7:36 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Did you see the ball joint replaced? Wonder if no work was done and the PO got a shady shop to pass it through inspection. Was it one of those "certified and E-tested for $500 more" deals?
