Shit, i think i just fried my truck!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06BLUEDBLSPORT, Jan 22, 2009.
  1. Jan 22, 2009 at 5:55 PM
    #41
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    depends which it is... if it's the wrong fuse you can get a pack up 5 of em for like $3
  2. Jan 22, 2009 at 5:56 PM
    #42
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    depends on which one you blew...they have to match...both physical and amp size...theyre color coded tho...so if you blew a dark red one...then replace it with such...and the amp rating is stamped on each one...easy as pie
  3. Jan 22, 2009 at 5:56 PM
    #43
    Snyperx
    Snyperx Seniore Marcos
    Should have a few spares in the box yes.
  4. Jan 22, 2009 at 5:57 PM
    #44
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....and more than likely he blew a blue 15 amp fuse.
  5. Jan 22, 2009 at 5:59 PM
    #45
    06BLUEDBLSPORT
    06BLUEDBLSPORT [OP] Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    sounds easy enough, not i got another question for you all, how do i fix the clock, when the head lights are on its clear, but when the head lights are off the numbers turn in to partial straight lines
  6. Jan 22, 2009 at 5:59 PM
    #46
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    So are your map lights still out along with your overhead light? If they are working along with the radio but your clock is not reading out right it may be that you did something to the clock in all this. I know in my 2005 that when I loose power to my clock, the radio goes along with all the cabin lights.
  7. Jan 22, 2009 at 6:02 PM
    #47
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    naw the radio works fine i think, when i turned my truck on it played but i didnt push any buttons, and just my lights are out everything so far works as they should
  8. Jan 22, 2009 at 6:03 PM
    #48
    JimBeam
    JB
    2015 Tundra
    try everything...horn...wipers...etc...
  9. Jan 22, 2009 at 6:03 PM
    #49
    surfsupl
    Gregg
    WestCoast
    Are the bulbs burnt out?
  10. Jan 22, 2009 at 6:04 PM
    #50
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    You have to look at the door you pulled off. it has a diagram of the panel on the back.
    Its probably just a popped fuse, but I would definitely be suspect of that LED dome you have, it sounds like its shorted. Take it out.
    Go buy a volt meter and learn how to use it. If you're smart enough to be modding your truck, you're smart enough to learn how to fix it when you screw it up.
  11. Jan 22, 2009 at 6:06 PM
    #51
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    Should i try them with the battery disconnected?
    they cant be, because i tried my old bulb that i took out of the dome light when i put my led in and that didnt work either
  12. Jan 22, 2009 at 6:07 PM
    #52
    JimBeam
    JB
    2015 Tundra
    no connect the battery...they wont work with it disco-ed
  13. Jan 22, 2009 at 6:07 PM
    #53
    TacoNut
    Adam
    Denver, Co
    as long as the key is out so that what ever you're pulling is also OFF no you should be fine
  14. Jan 22, 2009 at 6:09 PM
    #54
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    well that sounds easy enough
  15. Jan 22, 2009 at 6:14 PM
    #55
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    im gonna do it tomorrow
  16. Jan 22, 2009 at 6:24 PM
    #56
    surfsupl
    Gregg
    WestCoast
  17. Jan 22, 2009 at 6:31 PM
    #57
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    always disconnect the NEG terminal first on the battery
  18. Jan 22, 2009 at 7:00 PM
    #58
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    Well alright, i decide to go out with a flash light and get on the ground and start at them fuses, after pulling out the cab fuses i decide to take a look at the engine bay box and there i saw a fuse that read dome and i pulled it out and saw that the fuse didnt look burnt out but didnt look normal so i did not have an extra 7.5 fuse and decide to put it in and when i did the map lights shot on and i put in my old dome light and everything works great now and the clock is bad to normal, thanks guys for the help!!
  19. Jan 22, 2009 at 7:43 PM
    #59
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    Haha you got that right!!
  20. Jan 22, 2009 at 7:52 PM
    #60
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    glad to hear you fixed it, but your ass shoulda gone to pepboys or kragen and bought a kit to check all fuses. its a little plastic peice with metal rods and a led light on it. you just go through all fuses one by one till you find the one that doesnt light up. trucks should really be taken to dealerships for strange noises lol.
