Shitbox Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by JavaTripper, Feb 26, 2024.
  1. Feb 26, 2024 at 8:58 PM
    JavaTripper
    JavaTripper [OP] New Member
    Hunter
    Shitbox
    Hey there everyone, long time Tacoma driver and first time poster. My Tacoma was recently struck and damaged after I put a bunch of work into it, and I was wondering if anyone could give me some estimates as to what I could get to sell it right now, as is.
    In the beginning of Jan. I replaced the blower motor, the battery, the engine air filter, changed the oil, and I also put two new tires on the front because the 2 previous were wearing unevenly from a previous wreck. The engine head gasket needs to be replaced, as well as the brakes. The suspension is also not in the greatest shape, but the 4WD works like a charm. The engine has a little over 225,000 miles on it.
    I've attached photos of the body damage, but I'd rather not drive it anywhere so I haven't been able to get an estimate from a shop as to what damage actually occurred. I have also not been able to get the hood open, but the only fluid that leaked out when I was hit was the wiper fluid.
    Many thanks to anyone that replies
  2. Feb 26, 2024 at 9:11 PM
    Madjik_Man
    Colorado Front Range
    Year?
    Model? (Looks like a double cab since I think I see rear headrests)
    Engine?
    Transmission (if not a double cab)
    Frame condition?
  3. Feb 26, 2024 at 9:14 PM
    JavaTripper
    Hunter
    Shitbox
    It is a 4 door, v6 3.4L, and the bumper is fubar, I'm not too sure about the rest of the front end frame to be honest. Most of the damage is viewable from the pics, besides some slight door panel rubbing by the driver side door.
  4. Feb 26, 2024 at 9:35 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Where you located.....I'd love to buy that truck from you....
  5. Feb 26, 2024 at 9:35 PM
    JavaTripper
    Hunter
    Shitbox
    Denver Metro area
  6. Feb 26, 2024 at 9:37 PM
    O'Silver_Taco
    MD
    And probably wouldnt count on a head gasket.....
    ....it probably needs new heads......ugh.....
  7. Feb 26, 2024 at 9:38 PM
    O'Silver_Taco
    MD
    I would figure $6K~$7K in parts.......not including the labor....
    and thats a lot of money considering it'll need a new rack and tranny in next 100K or so.......thats another $4k...
    And then there is the frame curse......if you got it.....you got it....
    treyus30 likes this.
  8. Feb 26, 2024 at 9:45 PM
    O'Silver_Taco
    MD
    And dont call it a shit box......they have feelings you know.....
    ......there's no bad trucks, just bad owners.
    fiftysix, Laxtoy, Old metals and 3 others like this.
  9. Feb 27, 2024 at 3:50 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Really hard to say until you start dismantling the front end. If it were me, I would remove what’s left of the front bumper to get a better idea. If the frame isn’t jacked I would start hitting the salvage yards looking for a donor Tacoma that’s been ass-ended but still has the front end intact.
    Here’s a parts list to give you an idea of what’s involved.
  10. Feb 27, 2024 at 6:12 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Frame condition is a big selling point.
  11. Feb 27, 2024 at 6:25 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Previous wreck??? Never repaired properly so the tires were wearing?
    Looks like you rear-ended somebody... and it needs brakes? After a prior accident? Did it need brakes before the prior accident? Also rear-ending someone?
    I'm inferring a lot here, and perhaps not justified at all... but it sounds like a train wreck.
    Jeffch likes this.
  12. Feb 27, 2024 at 9:30 AM
    PathFinder1776
    PathFinder1776 Well-Known Member
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    Depends on what you can do yourself. If you're paying someone around here to fix that it'll total the truck for sure. Especially if you have to get into straightening up the frame and suspension so it will align properly. It can be done fairly easily if you can do the weld/fab/alignment yourself, it isn't terribly complex. The body work is pretty easy too. But if you're in a position where paying someone else is necessary it's going to be up over 10k pretty fast in this area.
    Ozark_RegCab and billybop90 like this.
  13. Feb 27, 2024 at 12:26 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    To be clear, op wants to sell, not repair and is asking us of the value.
    Value is based on who wants it. O’Silver_Taco is offering you money, that’s the best case, find an interested party on Craigslist or similar. Otherwise it’s salvage based on its condition.
    Calling it a shitbox, not the best selling tactic
  14. Feb 27, 2024 at 12:32 PM
    abauer10.beachside
    abauer10.beachside Well-Known Member
    2004 Tacoma prerunner TRD off-road double cab
    N/A
    I’d reckon it’s worth about treee fiddy :rolleyes:
  15. Feb 27, 2024 at 12:56 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    Tires wearing from a previous accident makes me think the frame was already bent and is now probably even more bent
    CO MTN Steve likes this.
  16. Feb 27, 2024 at 2:25 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Honestly difficult to say what you can get out of the vehicle in its current state. As others on this board have put it, everything depends on the stuff that is "skin deep" i.e. components, drivetrain and of course the frame. Repairs to the vehicle via a professional body shop will IMHO surpass the 10K mark as Pathfinder1776 stated, depending on what surprises behold you and if you really love your truck that much. If you plan on selling your vehicle on craigslist get ready for a lot of lowballing tire kickers that will drive you nuts sometimes. What-ever you decide keep us in the loop and let us know how it goes, hopefully everything works out for you.
  17. Feb 27, 2024 at 4:34 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I’d guess $2k and that depends on how far past registration it is and any back fees.
    It’s really not in that good of condition and “previous wreck” causing tire wear and now a front end collision, and needing new heads (at minimum) and an automatic with 225k… that’s just so much in questionable condition that it’s a parts truck or a project for someone that likes doing a lot of work.
  18. Feb 27, 2024 at 7:58 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Thousand bucks tops. 5k minimum to get that back to likeable and then I'm still stuck with a salvage title. Anything leftover is consumed by my free labor
  19. Feb 27, 2024 at 8:22 PM
    JasonLee
    15 TRD OffRoad
    Oh yeah, OP never said if this is a PreRunner or 4x4 as well.. I may go down to $1k if it’s a prerunner.
