shock absorber BOLT???!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by shepnuts, Mar 25, 2011.
  1. Mar 25, 2011 at 4:55 PM
    shepnuts
    shepnuts [OP] Member
    I cant seem to find the bolt that goes thru the bottom bushing of my shock absorber. Any body know where i should look for this part? the truck is an 01. Last time i changed the shock i didnt tighten it enough and it rattled out.
  2. Mar 25, 2011 at 4:58 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    grade 8 bolt from the hardware store with a nylock nut should work fine
  3. Mar 25, 2011 at 5:05 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    no matter what nut you get, use locktite. and it should be a 5/8th's course thread bolt.
  4. Mar 25, 2011 at 5:08 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    I dont know what size it is, but its definitely a metric bolt so it cant be 5/8ths.
  5. Mar 25, 2011 at 5:11 PM
    98_Mud_bug
    lucedale Ms.
    ok then equivilent size to a 5/8th's bolt. i broke the factory bolt off in mine and thats what is stuck through mine.
  6. Mar 25, 2011 at 5:14 PM
    Yoytoda
    Roland
    completely stock
    doesnt matter since its a through bolt. as long as its close... as in there is no play in the mount
  7. Mar 25, 2011 at 5:33 PM
    shepnuts
    its not a thru bolt, and the thread doesnt match anything ive found
  8. Mar 25, 2011 at 5:36 PM
    Yoytoda
    Roland
    completely stock
    front or rear?
  9. Mar 25, 2011 at 5:36 PM
    shepnuts
    what is the metric conversion for 5/8ths?
  10. Mar 25, 2011 at 5:37 PM
    shepnuts
  11. Mar 25, 2011 at 5:38 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  12. Mar 25, 2011 at 5:40 PM
    shepnuts
    thanks. I assume i just need to check the length and get a 16mm coarse thread bolt sumwhere
  13. Mar 25, 2011 at 5:40 PM
    Yoytoda
    Roland
    completely stock
    oh ok...
    go to a small hardware store, not like homo depot or lowes.
    try an ace hardware, they usually carry more unique threads like metric fine thread
  14. Mar 25, 2011 at 5:41 PM
    Yoytoda
    Roland
    completely stock
  15. Mar 25, 2011 at 5:42 PM
    shepnuts
    actually im thinking its fine thread
  16. Mar 25, 2011 at 5:43 PM
    shepnuts
  17. Mar 25, 2011 at 5:44 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Since it's missing, just take the top one off and to the hardware store.
  18. Mar 25, 2011 at 5:45 PM
    shepnuts
    only problem is i live on the Big Island. Ace, home depot, lowes are my choices. And none of them have it.
  19. Mar 25, 2011 at 5:46 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You should have a Fastenal. They have everything.
  20. Mar 25, 2011 at 5:47 PM
    Yoytoda
    Roland
    completely stock
    that sucks... dealer may have one
