Shock absorbers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by moweebo, Jan 24, 2021.
  1. Jan 24, 2021 at 12:53 PM
    moweebo
    moweebo [OP] Member
    I have a 2" lift on my rig. i need some tips on what kind of shocks to use to compensate? I just replaced my leafs but there not holding form very well, which causes me to wonder if i even needed new ones in the first place..
  2. Jan 24, 2021 at 12:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Bilstein 5100, OME Nitrochargers, Fox, King, ADS, Icon...
    This is asked every single day
    crazytacoman likes this.
  3. Jan 24, 2021 at 12:55 PM
    moweebo
    moweebo [OP] Member
    That doesnt help me.
    Ronbo1 likes this.
  4. Jan 24, 2021 at 12:58 PM
    Ronbo1
    Ronbo1 Well-Known Member
    Ron
    2020 Tacoma SR
    Topper, 3" front lift, Duratrac 265/70 r16's
    No, it doesn't. The person is being a wise-ass. I myself don't have the knowledge to help you. Maybe a kind and well-intentioned soul will step up.
  5. Jan 24, 2021 at 1:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You asked what shocks to accommodate your 2" lift.
    Listed above are shock manufacturers that provide bolt-in solutions to your question. You were answered to an extent because your question left a lot of missing information.
    Maybe you can specify if you meant fronts only, rears only, budget, usage?
    ciaman96 likes this.
  6. Jan 24, 2021 at 1:02 PM
    ciaman96
    ciaman96 Well-Known Member
    Tucson
    2001 Reg Cab Tacoma 4x4
    OME Lift, E-locker, interior swap
    This is a very common question on the forum. You can use the search function and find a bunch of info on suspension options and setups.
    Your budget, goals, and use case will determine what setup is best for you.
    Kwikvette and Ronbo1 like this.
  7. Jan 24, 2021 at 1:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Apparently that too could qualify as being a wise-ass :rofl:
    Really though, this question is asked more than once every single day in this section alone. If one scrolled down a bit, they'd see a fresh thread asking the same thing.
    Since one can't be bothered to spend the time looking that it took to create the thread, I'll entertain the question and offer advice.
    All depends if the OP wants to provide information needed in order to answer said question.
    ciaman96[QUOTED] likes this.
  8. Jan 24, 2021 at 1:41 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Not sure what you mean by compensate, but the bilstein 5100 shocks have the ability to adjust them up to 2"
