shock and spring Q
Discussion in 'Toytec Lifts' started by GotLift37, Dec 15, 2009.
  1. Dec 15, 2009 at 6:40 PM
    GotLift37
    GotLift37 [OP] Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    To start. this is for an 07 4runner. no longer have a tacoma but this forum is still one of the best to be on.
    ok to start i have a few questions.
    Front OME Lift Coils 885
    which shocks? would work best? Im wanting the most lift possible out of both of them. Then also for the front would it be possible to add the coil spacer for an additional lift? say the 2.5" spacer plus the 2" of lift from the coils. that setup along with the Front Adjustable Bilstein Shocks on their 2.5 setting? how much lift would I get out of that setup?
    now for the rear of course matching shocks. I already have the 2" lift coils. would adding the 1.5 spacer work? extended brake lines are a must in my book. either way im probably gonna try it. my goal is 35's on my runner with min. rubbing. also in this mix 1" toytec BL i would get too.
    my main question is which shocks with the ome lift coils 885.
    thanks for the time and patience in reading my post. I know its not very grammatical. ive had several 16 hour days at work in a row with very little sleep.
    -Matt
  2. Dec 16, 2009 at 10:06 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Hey Matt,
    No problem, you can post up here :)
    The front shocks you would want to keep with the OME brand. Here is the shock I would recommend. It is OME's latest release of this shock!
  3. Dec 16, 2009 at 4:29 PM
    GotLift37
    down south
    07 4Runner 4WD
    what about the 884's?
  4. Dec 17, 2009 at 3:35 PM
    Toytec Lifts
    Rocky Mountains
    Yesterday was a loooong day for me.. Sorry about that.
    All the OME coils for the 2nd gen tacoma need the top plate spacer to conclude the full three inches.
  5. Dec 17, 2009 at 5:24 PM
    GotLift37
    down south
    07 4Runner 4WD
    alright i have that. i should be golden
