Shock and Strut replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by bob154, May 18, 2010.
  1. May 18, 2010 at 12:36 PM
    bob154
    bob154 [OP] Member
    I need to replace my shocks and struts whats a good setup. My friend keeps telling me to get ranchos as Monroe has a rebate now but are they any good?
  2. May 18, 2010 at 12:40 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You probably are not gona find many people on here that will recommend the ranchos. Some of the most popular are the Bilstein 5100s, but they most likely are not available due to nationwide backorders. Are you wanting to lift your vehicle or just need to put on new shocks?
  3. May 18, 2010 at 12:43 PM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    Billies or OME
    If you do decide to lift later, you will be one step ahead of the game.
  4. May 18, 2010 at 12:48 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    My truck is in the shop getting the Billys installed right now
  5. May 18, 2010 at 12:51 PM
    bob154
    bob154 [OP] Member
    I would like to lift it eventually (2-4 inches) but i can't afford it as of now.
  6. May 18, 2010 at 12:53 PM
    scocar
    scocar Patron of the Farts
    I am in the process of upgrading my suspension, and am putting on Bilstein 5100s, but as Dan points out, there is a nationwide shortage, and they are a little spendy. A few of the vendors on this site just got some in (after several months), and they were all gone pretty much the next day.
    The 5100s can be used in conjuction with a lift of up to 3 inches, but also at stock height, and also just to level the front end with the back. I have attached a brochure about the 5100s so you can see if that is what you want.
    If you do not intend to do any lifting, another alternative may be the aftermarket Bilstein HD shocks. [whoops, slow post]
    Check out the Bilstein website.
    Reagarding Ranchos, I had some on my 93 Toyota, and they were really harsh and stiff. I can't recall what model, but a really basic one. On rough highway, it made me want to stop driving. Really bad.
    Hope this helps.
  7. May 18, 2010 at 2:23 PM
    shift96
    shift96 Well-Known Member
    I have Rancho 5000's on mine and am happy with them. Don't understand why there is so much hate for them.
  8. May 19, 2010 at 4:48 AM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Thanks for posting this PDF. Great info for someone like me who is looking for info on shocks..
  9. May 19, 2010 at 9:57 AM
    bob154
    bob154 [OP] Member
    Thanks guys. I was looking around today and quite a few people were saying that the KYB gas adjusts were a good set. Are they?
  10. May 19, 2010 at 10:31 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Check out the Monroe too.
  11. May 19, 2010 at 11:50 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The new OME 90000 Series are really great shocks.
  12. May 19, 2010 at 12:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Rancho is a good shock, I'd go with just about ANY shock other than a Monroe but I digress I recently put ride height adjustable Bilstein 5100's & couldn't be happier, its a pretty easy process changing shocks yourself but first & foremost you have to have a coil spring compressor to safely do this......
  13. Jan 3, 2013 at 7:36 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    The monroes on my Bronco lasted just under two years. The Billie 4600's on my '93 were going strong four years later.
    Nothing really wrong with Rancho; They're well built and work and last good, but I feel they're overpriced. Furthermore, once you run your first set of Bilstiens, you won't be missing anything Rancho. :D
  14. Jan 3, 2013 at 11:23 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If the truck is stock the Bilstein HD's are a great shock. That's what I run in mine. They were readily available 3 months ago when I bought mine. I will say they are HORRIBLE with back orders as a company though.
  15. Jan 3, 2013 at 12:00 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I've got KYB's on mine. Seem almost as good as the OEM shocks.
  16. Apr 10, 2014 at 5:22 AM
    Doug001
    Doug001 Member
    Georgia
    05 Tacoma PreRunner
    how much should it costs to have a set - labor wise- of 5100's installed on an 05 Taco PreRunner? Also, How do I know what setting to tell the mechanic to dial them in on?
