Shock and struts whole set
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tsean, Jun 3, 2023.
  1. Jun 7, 2023 at 8:45 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Please talk to any shop you might deal with some will not install customer supplied parts. **Which means parts you bought .
    Always make sure before buying anything you can`t install yourself.
    sean.hwy likes this.
  2. Jun 8, 2023 at 4:51 AM
    Tsean
    Tsean [OP] Well-Known Member
    Tsean
    ok got it thx
    Bivouac likes this.
  3. Jun 8, 2023 at 5:21 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I like using Toytech to order shocks. Check them out
  4. Jun 8, 2023 at 11:32 AM
    1997TacomaSR5
    1997TacomaSR5 OG TACO - 3ook+ ...where 2 wheel next
    It's all a learning process :)
    Tsean[QUOTED][OP] likes this.
  5. Jun 8, 2023 at 3:03 PM
    Tsean
    Tsean
    so useful information thank you ill give a shot
    Red_03Taco[QUOTED] likes this.
  6. Jun 8, 2023 at 10:55 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Before you go all in on new suspension- I know you've mentioned that you have bad ball joints, and I would like to strongly suggest that you take care of any issues with those before you consider suspension upgrades. Doesn't matter what shocks you get if your wheels break off.
    Tsean[OP] likes this.
  7. Jun 9, 2023 at 9:53 AM
    Tsean
    Tsean
    How do you know that ball join up arms are in bad condition
    1997TacomaSR5 likes this.
  8. Jun 9, 2023 at 10:00 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Basically, if you don't know when the last time the lowers have been replaced, they need to be replaced with OEM only parts. The uppers are slightly less critical- check them for movement with a pry bar.
    The lower ball joints fail without warning- just search these forums, there are countless threads with aftermath photos.
  9. Jun 9, 2023 at 10:08 AM
    1997TacomaSR5
    There must be some sort of warning for the LBJ :notsure:
    Snapping sound?
    Crunching?
    Grinding?
  10. Jun 9, 2023 at 10:13 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Nope. Unless those sounds are related to the aftermath of the failure.
    rocknbil likes this.
  11. Jun 9, 2023 at 12:13 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    If you live to tell of the sound, consider it a lucky day. I can't locate it but there is a thread posted by someone that had a dash cam running and though he never said, comments speculate an LBJ let loose, went off the road, into a tree, the carnage is downright scary. From what I can tell it's hit or miss, they can last forever or snap in a week, there's no rhyme or reason, it's not always hard offroad bashing. In the video he posted he was just cruising down the highway when it let go.
    Special thanks to @Andy01DblCabTacoma and @Kwikvette for their input in this thread, I'm in the same boat, looking to replace shocks/coilovers. I'm sure I can handle compressing the springs and just replacing the shocks but a preassembled set would be so much easier and it's good to know there are some worthy non-OEM options out there.
    Bivouac, Tsean[OP] and Kwikvette like this.
  12. Jun 9, 2023 at 12:50 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Here's the thing: It's not hit or miss. It's a hit every time. They are a wear item, and they need to be replaced. If you don't replace them, they fail.
    People don't like to replace things unless they are physically broken (there are still folks driving around on OEM shocks and springs swearing that they are still OK- they aren't), or showing signs of breakage.
    Bilstiens + OME 88x coilovers have been the goto option for 20+ years.
    rocknbil[QUOTED] likes this.
  13. Jun 9, 2023 at 3:23 PM
    rocknbil
    Bill
    The hit or miss refers to when. 5 years? 10, 20? That's what I meant. I did the ball joint test on my '03 and there was zero play with a 36" crow bar. I almost didn't do the job, but put in new ones anyway. Could have been 10 more years, could have been tomorrow. :p
    Bivouac likes this.
  14. Jun 9, 2023 at 3:29 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I can't find a definitive reference anywhere (easily), but if I recall correctly, the replacement schedule for the ball joints is something like every 75K. My '01 was part of the ball join recall, and I've replaced them twice since.
  15. Jun 9, 2023 at 3:50 PM
    #35
    1997TacomaSR5
    How about mileage?
    That's gotta be a factor!
    75k seems shorttime is all
  16. Jun 9, 2023 at 4:32 PM
    #36
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    They are a known weak link. 75k is low is IMO.
    1997TacomaSR5[QUOTED] likes this.
  17. Jun 9, 2023 at 5:07 PM
    #37
    1997TacomaSR5
    This is for aftermarket LBJ or the OEM yota LBJ?
  18. Jun 9, 2023 at 8:09 PM
    #38
    Tsean
    Tsean
    Thank you guys for the great information, so I really appreciate willing to check it soon. LBJ
  19. Jun 9, 2023 at 8:13 PM
    #39
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    OEM. Dont even think about non-OEM lower ball joints. There is another thread detailing some of the internal differences between the OEM and aftermarket parts, and the aftermarket ones are complete junk. Non-OEM change interval is more like 30k or every other year if you're lucky.
  20. Jun 9, 2023 at 9:04 PM
    #40
    Bivouac
    When I changed mine they were still tight.
    Around 150,000 miles
    That is what bothers me the when ? Why some fail and others last forever.
    If your not a hard core Toyota person so many things you never hear of. Your average Tacoma owner has no idea of the poor ball joint design.
    In our State safety inspection as long as they are tight there good to go.
