shock broke
Discussion in 'Suspension' started by jason1kyle, Jul 24, 2010.
  1. Jul 24, 2010 at 7:51 PM
    jason1kyle
    jason1kyle [OP] commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    Sorry guys just wanna bitch a little and find out who all has had this happen. So I go to auto shop to get my ome 885's put on my 5100's set at .85. 1st one goes on just fine then the second one kept giving us trouble ( the spring kept bending out instead of staying straight so we finally get it on good and start letting the pressure back and POP POP f*** me the ring gave out and stripped the metal off the shock so now i have my truck in my garage with the front end half out and i have to put my stock set up back on. Needless to say i'm pissed. Tried calling billstein but they dont have 24/hr customer service so i have to wait till monday. Any body else have this problem and what did you do.
  2. Jul 24, 2010 at 7:58 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    sounds like the ring wasnt in the groove properly. good luck getting billistein to warrantee it...
  3. Jul 24, 2010 at 8:24 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^
  4. Jul 24, 2010 at 8:30 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I don't have experience with the billies, but I use to run koni struts in an old car and they had an almost identical ride height adjustment. Eventually with time the adjustment ring and seat would fail. This is one reason why I went with ome over the bilstein.
  5. Jul 24, 2010 at 8:31 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
  6. Jul 24, 2010 at 9:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2?
  7. Jul 25, 2010 at 12:21 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x3, exactly what came to mind when i read "the spring kept bending out instead of staying straight"
  8. Jul 25, 2010 at 1:16 PM
    jason1kyle
    JOHNSON CITY, TN
    if it was upside down then it came from bilstein like that and the ring was in the groves as best as it could be so i guess i will see what happens
  9. Jul 25, 2010 at 1:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just a heads up....with the 885 and 886 coils,.......you shouldnt preload those....so the 5100's should stay on the stock setting.
  10. Jul 25, 2010 at 1:23 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
  11. Jul 25, 2010 at 1:31 PM
    TexasTacoma37
    The spring perch doesn't come installed from bilstein. It won't fit in the box that way.
    Can you post a pic of the spring perch so we can see if it's right-side-up?
  12. Jul 25, 2010 at 1:40 PM
    jason1kyle
    JOHNSON CITY, TN
  13. Jul 25, 2010 at 1:43 PM
    TexasTacoma37
    ^^^ Yep, those are upside down.
  14. Jul 25, 2010 at 1:44 PM
    jason1kyle
    JOHNSON CITY, TN
    fml are u serious
  15. Jul 25, 2010 at 1:46 PM
    Yoytoda
    Roland
    completely stock
    i believe those are upside down. if you look at the flat side there is a recessed area for the snap ring to sit in to hold it in the groove.
  16. Jul 25, 2010 at 1:48 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
  17. Jul 25, 2010 at 1:49 PM
    Yoytoda
    Roland
    completely stock
  18. Jul 25, 2010 at 1:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeppo! Upside down.
  19. Jul 25, 2010 at 1:51 PM
    jason1kyle
    JOHNSON CITY, TN
    yeah they are upside down fml cant belive i didnt catch that or the mechanic that was installing them well thanks for the help guys
  20. Jul 25, 2010 at 1:52 PM
    TexasTacoma37
    Yeah, and that definately caused the failure of the snap ring.
    With the spring perch upside down, not only are the springs compressed a whole lot more, but there's nothing to slide over the outer edge of the snap ring to keep it from unseating.
    Turn them upside down and slide the seat over the ring and you'll see what I mean about keeping the ring seated. The perch forms a sheath around the ring and holds it in place.
